The relationship between price and performance in this hobby is a fascinating one. Some might even choose to allocate resources towards software rather than the hardware, once he’s reached a certain level of equipment and sound.
I have decided to spend much more money on the turntable then on the arm and cartridge in pursuit of better sound. One might look at my cartridges and say the Colibrís are expensive, but knowing now when I’ve learned, and if forced to choose for budget allocation reasons, I would keep my vintage Technics moving magnet cartridge and vintage SME tonearm, both extremely high value performers, and be done and put any and all remaining resources toward the best high mass unsuspended belt drive turntable I could find.
I really appreciate all the time people have spent thinking about this and offering advice.
Given the difficulties involved in actually auditioning, I had tried to narrow the field, perhaps inappropriately, to two high-mass designs, both with the possibility of multiple tonearms, both with vacuum hold-down, one linear and one pivoted.
You know it's better than a Crosley, so this thinking is a distraction from the goal... (his P10 review is extremely positive) - whereas others on the forum would say the P10 is basically a Crosley.
For your situation I want to disagree with this approach, as I strongly believe changing tables will be a paradigm shift...but you must start somewhere. Any advancement of your experience will be useful. And buying the cart first breaks up the expenditure into two piecesIt does seem, though, like it might be interesting to start by keeping everything the same except for the cartridge, and see what difference that can make. Save for the difficulty of mounting
So here's the thing
In Boston, if you ask
- PeterA, he will tell you to buy a Microseiki.
- Al M will ask you to go digital. He will still provide you some advice on TTs and records
- Ack will mod your current Rega
- And Madfloyd will get excited along with you about what he should buy next.
I am not sure what VLS will say.
To be clear, I have no general problem with digital content. I just think we -- or I -- lost aspects of the listening experience when I went digital...and so, I've tried to bring that back as an additional option...not an exclusive one.Just saw that now. LOL. No I won't ask dnanian to go digital (depending on his musical interests), but I would expect him not to ask me to go vinyl either.
Yes, I know a tiny bit about turntables and records. I do know that when I listen to vinyl, which I enjoy in my friends' systems, I want a fully analog experience if possible. *No* digital step anywhere -- that's also why I don't have a particularly high opinion about today's celebrated "vinyl resurgence". It begs the question, what's the point if 90+ % of those records are digital sourced.
Yes, agree with you 'gleeds', but choosing a better a Phono Stage I can see being a mine field as there are so many to choose from. The Rega Aura (which is Rega's Reference Phono Stage - not their cheaper 'Aria' which some people are mistaken by) was an easy choice as I bought the Rega P10 at the same time.Given the level of your table, arm, and cartridge, you might want to consider something I would most definitely think about a considerably better phono stage than the Rega.
So here's the thing
I bought a one owner second hand Kuzma XL DC with a 4 Point 11" and a My Sonic Lab Eminent EX cartridge from a Kuzma Dealer in Norway blind without listening to it or even seeing it for my UK system. Always wanted a XL DC and have been waiting to purchase the right one for some time now.
Loving the XL DC especially playing through my Hifiman EF1000 & Susvara Headphones which is light years better than my Rega P10 with Apheta 3 (guess it should be considering the much higher cost).
Haven't played one CD since I have set up the XL DC (over the last four weeks).
I will now be selling my Rega P10 with Apheta 3 (once I get the Apheta 3 repaired via Rega which I accidentally bent the cantilever with my hand without even knowing about it !).
Now considering whether to upgrade the Rega Aura Phono Stage or not to a much higher level Phono Stage ?
You might find the Konus Audio Vinyle 3000MC (http://www.konus-audio.com/vinyle-3000mc.html) interesting. Minimalist design, current input, sounds remarkably alive. The gentleman who builds Konus is also the worldwide distributor for Fuuga. Really nice phono.I also use the same tonearm on a Kuzma Stabi M turntable. I also use a low resistance cart like you, in my case a Miyabi Fuuga. What I found out is; the best I can get out of a low resistance cartridge is via transimpedance amplification. For this there are not many options, less than your fingers in both hands. If you are a big spender you can go CH Precision P1 and use its current input. If you are not, I have a great suggestion for your cart. It is the channel D Lino c 3.3. It is not very expensive, operates from battery, dead quiet, has the best measured performance from stereophile and has actually great performance right here in my room! This type of phono eliminates loading so you just plug it in. The input has to be balanced and if you want to get the last ounce of performance out of it, you go balanced output too imho.
CHANNEL D - Lino C
www.channld.com
Thank you Kodomo for your suggestion of two phono stages for my My Sonic Lab Eminent EX cartridge. Much appreciated.I also use the same tonearm on a Kuzma Stabi M turntable. I also use a low resistance cart like you, in my case a Miyabi Fuuga. What I found out is; the best I can get out of a low resistance cartridge is via transimpedance amplification. For this there are not many options, less than your fingers in both hands. If you are a big spender you can go CH Precision P1 and use its current input. If you are not, I have a great suggestion for your cart. It is the channel D Lino c 3.3. It is not very expensive, operates from battery, dead quiet, has the best measured performance from stereophile and has actually great performance right here in my room! This type of phono eliminates loading so you just plug it in. The input has to be balanced and if you want to get the last ounce of performance out of it, you go balanced output too imho.
CHANNEL D - Lino C
www.channld.com
Just to let you know, I had rega reference ios with the first apheta on an older rega turntable years ago when 1st apheta came out. There is not even a contest with that and with a Lino C and a low resistance cartridge for me.Thank you Kodomo for your suggestion of two phono stages for my My Sonic Lab Eminent EX cartridge. Much appreciated.
The Channel D Lino C3.3 looks a very interesting phono stage, and like you say not very expensive compared to other current input phono stages like the CH Precision P1.
Very nice TTs 'Hydrology' and very nice photos.I've set up a Galder/Odin/AirTight PC-1 Supreme and a TechDas V Premium / Kuzma 4 Point 14/EMT Novel in recent months and while there are many variables in both of these to determine which is the better overall performer, I remember being more impressed with the TechDas combination overall. Having said that, that Galder is a piece of art!
Suffice to say, either TT you are looking at is a HUGE improvement over the Rega you have and I doubt youwould be unhappy with either.
