From what material is it made ???
I'm seeing this question alot around here , why is this so important ? Do you have a preference when it comes to materials Used ..?
Yes, its one of the most important basic issues in my opinion , first of all , the energy used to set the housing in motion gets lost as signal energy , these vibrations will interfere also with the constant changing ,music signal and cause distortion .
First HPL (melaninepaper drenched in phenolic resin), second (high grade alloy) aluminium , i m not 100 % sure yet which is the most natural sounding material .
It also comes down on how the internal bracing is done , good results can also be achieved by combining HDF and MDF for example
just MDF is ...... so 80 s![]()
Yes it is quite challenging vs single point source ...
I guess time coherency is now a thing of the past .....![]()
Will do so. Thanks for the tip. I have never heard NOLA.Listen to the NOLA's decent job ...![]()
If you read the specifications you would know that is not at all a problem with this speaker. It is fantasticly phase coherent.
The picture or rendering of the Avalon Tesseract doesn't give a good impression of how it looks from other angles than straight from the front. I have seen an illustration from the side and it looks like a cross between Vivid Audio Gaya and Wilson"s bigger models MAXX, Alexandria and XLF. It does however have its distinctive look due to all the facettes from the Tesseract shape. It's a real work of art and maybe the most striking shape of any loudspeaker enclosure I have ever seen. I haven't seen it from behind, but I guess it must feature two 15" bass drivers on the back too since the specification indicated 4x 15" bass drivers and only two are mounted on the baffle and none on the sides.
With a 2500W internal bass amplifier and 4x15" bass drivers in each speaker, it should be a monster on par with the Evolution Acoustics MM7 but in a more compact package.
i wonder how tough a load the Tesseract is with fewer woofers and mids? most Avalons have been somewhat tough loads for amps. you would think this Avalon could be an easier load.
i've always considered Avalons to be the most beautiful speakers, really works of art. the Tesseract has an interesting shape which might or might not be organic looking in person. it's certainly striking looking.
i'd love to hear it.
the 4 15" powered subs per side is similar to the MM7. however, the MM7 also has 4 woofers per side (verses 1 for the Tesseract) and 2 mids per side (verses 1 for the Tesseract), so in that way the MM7's are quite different.
i do hope that the Tesseract using 4 powered subs helps to set a trend toward powered integrated subs in 'uber' speakers as that will push 'uber' amp makers to focus more on refinement and less on brute strength. and i believe a true integrated powered sub is potentially the ultimate approach.
Mike - Avalons are not that tough of a load, I have had quite a few now and have powered them with very different amps, SS and tubed ones - sensitivity is not that great but impendence is quite flat at 6 ohms among the frequency band. I am actually using a pair of Ascents II with a 35 W/ch class A amp that plays great 85% or more of the music I hear.
Sorry, My science book would disagree..![]()
Physically with the head canting over and being non-adjustable I cant see how, at least WA makes theirs with some adjustment, getting them into focus somewhat and theirs are not time coherent...
OK different speaker but these aren't ...
http://www.stereophile.com/content/avalon-acoustics-indra-loudspeaker-measurements
Isn't it a little early to make any claims based on what we know about this speaker yet? I mean do we know the head can't be adjusted or if the crossover somehow has a adjustments to compensate for this?
