The only thing you’re doing I expect substantial gain from would be changing crossover caps. You will find personal taste in them, all are probably very good and measure the same, but have unique sound.
Already done TangoYou can also ask Sablon Audio to do internal wire of your horns. That will make a significant change in sound...since you already like the sound of this cable.
You may be surprised by what a simple Oyaide R inlet brings to the table and still scope to add a Bocchino IEC inlet at a later date.The only thing you’re doing I expect substantial gain from would be changing crossover caps. You will find personal taste in them, all are probably very good and measure the same, but have unique sound.
I’m currently mid way through updating my AG Duo Omega which is taking me longer than I thought and has exceeded my modest budget I’d allocated to the project due to discovering further areas for tweaking.
The binding posts have been changed from very basic WBT brass/Chrome to Audio Note Ongaku Silver and for the tweeter I had to use WBT 0705Ag. The tweeter crossover connected to the old binding posts via a brass bolt and star washer biting into a trace on the pcb, not the ideal connection. The new WBT allow the solder tag to be bent over and solder directly to the trace. At this moment in time I can not afford to change the cap to a Deulund SnCu and inductor to Jantzen Copper Foil in wax but will prioritise this next year.
Internal wires to drivers will be soldered directly to the driver wires and crossover and ‘grub screwed’ to the Mids posts. These links were kindly made for me by Mark Coles from Sablon Audio and replace the factory silver plated copper links.
The metal horn tubes are now damped carefully with sound deadening panels as in new production Duos.
Moving on to the Bass amps is where my initial upgrade thoughts started and I knew I had to remove the generic IEC inlet for an Oyaide R inlet. I’ve found this inlet to be both great sounding and economical. On opening the amp module I could see two fuses on the pcb screaming SR Blue fuse please!. There are also 4 opamps that could be changed to Burson opamps but I decided to leave these alone. All the caps looked fine, though I was tempted to change the 4 10,000uF caps for Mundorf MLytic AG, so left them alone.
Outside of the Duos I’ve upgraded my Sablon speaker cables to Bocchino spades like Spiritofmusic has done and upgraded the power cords to Prince Sablon Bocchino terminated cords.
I should be finished and back up and running in a couple of days and will post some comments but with so many changes and so much burn in going on it will be hard to allocate any changes. And, if it all sounds horrible I’ll tell you straight.
Here’s a few pics View attachment 57213 View attachment 57214 View attachment 57215 View attachment 57216
Hi Bill, I’ve never really contemplated DSP on the bass only because I was already quite happy with the sound and I never really noticed any discontinuity that others appear to be sensitive to. Plus, I like to keep the box count to a minimum.Barry did you ever consider doing your own XD version on the bass module only? Should be very straightforward should you fancy exploring that route. Not saying that it will be any better but interesting experiment.
A mini dsp 2x4Hd pcb arrived here a couple of hours ago. Just bought it to verify any benefits of corrections on the bass only using difficult rooms.
Finally powered the Duos up today and pleasantly surprised that not only do they work but they sound great too. Straight off they sound much clearer, greater transparency and vocals a bit more present. Bass is a touch too strong though after burn in I can adjust the settings if need be. Overall they sound more alive and the soundstage feels physical.
Let’s see how they improve after about 400 hrs of run time.
Well worth the time and effort involved.
Blue58
Hi Jatinder,The frame on my Duo's vibrates quite a bit when listening to loud music. I've tried tightening all the bolts.
I've recently put anti-vibration material inside the canisters (the black sticky rubber stuff you get for car panels) - this did reduce the frame vibration a little.
I'm now thinking about replacing the hard white washer that's placed between the mounting bolt and the frame. Maybe replacing that with silicone or sorbothane would reduce the transmission of vibration from the canisters to the frame?
I think maybe there ought to be another soft washer on the other side of the bolt as well for maximum dampening?
I'd be interested in your thoughts.
--Jatinder
