Best Sounding FM Tuner?
When we listen to analog FM radio broadcasts are we listening over analog radio transmission to a replay of a CD or a computer file by the radio station?
U.S. radio broadcasters are now simultaneously broadcasting both traditional analog signals and digital signals that can be picked up with a digital radio receiver. So you can have it either way, but the music will most likely come off a compressed file on a hard drive.
Thank you. (This is the answer I was expecting, but not the answer I was hoping for!)
I am going to sell my Magnum Dynalab MD 100.
FM today is CD quality with everything under 50 hz and over 15kHz filtered out!!
In Germany is from 30Hz to 15Khz sounds good with
classical music(concert recordings)
Rock and Pop i think comes from harddrive.
it is broadcast in two frequency bands, mono and stereo with radio data system extra (name of the radio station)
I purchased a Accuphase T-1200 Tuner last year I have to say it was one of the best all time audio purchase's in my 53 year audio career.
Sounds wonderful!
Regards
AJ
You purchased, IMHO, the single best FM stereo tuner ever manufactured! Performance-wise, there is nothing that can touch it. May I ask the name of the dealership from which you purchased it?
Is anyone familiar with the Denon TU-900?
How does the TU-900 compare sonically to the Denon TU-800 or to the Denon TU-850?
How does the Denon TU-900 compre to the similar Sansui tuners, like the TU-919?
The Denon TU-800 is a much better tuner than the TU-900 (3 IF bandwidth settings vs, 2 on the TU-900, and better specs than the TU-900). As for Sansui comparisons, the Denon TU-900 would be, IMHO, roughly equivalent to the Sansui TU-719 performance and sound quality wise. As always, YMMV
If you are trying to receive weak, distant stations ("DX") then a 88 to 108 MHz multi-element yagi antenna and rotator is the most effective solution (but not the most unobtrusive).
I just checked on the internet but none of the amateur radio antenna manufacturers I happen to be familiar with seem to make 88 to 108 MHz beam antennas.
However, this is a serious fixed, omni-directional (you cannot rotate it and point it at your target station to amplify the signals from the target direction and attenuate signals from the sides and back of the antenna) 88 to 108 MHz antenna by a good company which makes amateur radio antennas I used to use:
As a transmitting antenna it is overly rugged for receiving-only but it will do a great job!
An omnidirectional antenna is pretty much useless for DX’ing, and it will never have a gain greater than 1.
If you wish to DX signals you need a directional yagi FM antenna and they are becoming more difficult to source. However, Innovantennas (innovantennas.com) in England still makes some very good ones.
Their website will convert £’s to $’s and if you’re in the US you don’t pay the tax.
I believe this one is superb, and it’s about $335 plus shipping.
https://www.innovantennas.com/en/ou...ement-88-108mhz-op-desInnovAntennas shop.html
It’s specs are:
Typical Gain:11.30dBi
Typical F/B: 26dB
Gain at 10m (33') above ground: 17.62dBi
Power Rating: 3kw
Feed Impedance: 75? or 50?
Boom Length: 5.6m - 18' 5''
Weight: 4.82Kg / 11LB
Turning Radius: 3.0m / 9' 9''ft
Wind Loading: 0.5 Square Metres / 2 Square feet
Wind Survival: 331KPH / 206MPH
I find the wind survival rating particularly impressive.
What do you think of the best internet tuner? Or is that an oxymoron? I am just concerned about going for FM given that certain countries have already announced termination dates (even if they are being extended).
I sold the pair of good sounding Meridian 504 tuners we still had in the household last Fall. The motivator was the realization that neither the one in my wife's home office nor the second in our living room system had been used for a decade!
Are you looking for a tuner external to your music system ? Do you use a computer in your system to playback digital ? If so, you can use an app for FM/internet radio.
Otherwise they have standalone devices. Never used one of these, I use an app. Link below
Stand-alone internet tuners
Similar story, I had a Marantz MR78 tuner that I had for many years. I think I used it twice ! Once when I got it and then to check it before I sold it ... but it was pretty to look at when it was on..
Hi...I was reading about the Accuphase T1200 and thinking that (for us), it would be wonderful to have something so state of the art...but would prefer that it had internet radio to give us longevity of use. If there is something of that equivalent, that might be interesting.
I will take a look at your list. Thank you!
Marantz never had an MR78...u probably meant McIntosh
Back in the day I was into FM tuners. Had most of the top ones. Of them all I really thought the Yamaha CT-7000 sounded best although my Day Sequerra sure looked cool......
I stand corrected.. I should have remembered the walnut case!
The Accuphase T-1200 looks very serious, indeed!
I found a U.S. version Accuphase T-106,so i'll see how it stacks up to my other tuners. I have read about the T-1200 and the reviews are quite interesting. I have also contacted a tech who specializes in tuner upgrades. I'll post about my Accuphase later.
Reactions: Ron Resnick
What other tuners do you have in your collection?
Reactions: RogerD
I listen sometimes through tuner FM.
I had in the past some respectable tuners like Marantz 20 and Day-Sequerra (not the original 1). I ended my tuner journey with my favourite just for the cool looking, a SAE MkVI with nixies digits and the indispensable oscilloscope.
It does not sounds as the best Sansui or MR78 or again, a Sequerra neverthless it's very good to my ears.
What Is disappointing is the broadcast quality, going worse also for the RAI3 Channel that here in Italy granted in the past classical live concerts and music programming of fine quality. Now the dynamic compression is hardly used; all the FM world becomes of marginal importance in recent years, and the ghost of the FM shut-off is behind the corner.
Obviously I hope not.
Reactions: Barry2013
Hi Ron,
I have several Mcintosh MR78,MR80,MR66,and MR71. The 66 and 71 I just purchased so I can’t say which one I like the most yet.
My favorite so far is my Day Sequerra FM Reference.
I also have a Dynaco FM-3 that had been modified but sounds nice.
I suspect that the MR80, FM Reference, and the T-106 will be the best of the herd. The MR71 should be the best tube turner. I purchased the T-106 because a fellow on another forum told me it was the best of the 40 tuners that he has owned.
That’s it for me on tuners except when a friend tells me she is ready to part with her late husband ‘s Marantz 10B which he bought new.
