... well, I have been asking the wrong questions in too many different threads and probably not been articulating my own goals/ideas properly... so here I go again... ;-)
1.
I subscribed a lifetime membership for ROON many years ago - as I really like the software I want to build a digital system around it.
2.
I stream only for exploring new music, but in the end, I always buy stuff I like, be it on vinyl (primary source) or if not availabe on vinyl, I will buy the CD and rip it or buy the download - so "serious listening" will always take place by playing locally stored files (using the ROON software).
3.
I see two basic solutions, one would be to follow ROONs advice and keep the core and the streamer/DAC in separate rooms - thus I would have a Nucleus for example as core in the basement, fed by a server in the same room (or with internal storage), then have ROONs software do whatever it does and then run the file via ethernet to the router (Fritzbox) and from there via ethernet to the music room, where the signal will run into the streaming bridge and take it`s path from there...
Now this would mean sending the file through the home network, thus I would probably need to install proper ethernet switches - as from my reading here the main problem seems to by sound/file degredation due to noise/jitter being introduced to the file on it`s way through the home ethernet from the source to the endpoint...
4.
The alternative options would be a Core/Server/Streamer in one box placed in the music room, serving the DAC directly and not running through the home network... this would be Antipodes K22 or some Innuos for example. No more issues with added noise, as the file does not travel the ethernet route but is fed directly (basically like a CD transport feeding the DAC)... logically (to me) no more need for ethernet switches (the only reason for internet connection is to actually give ROON connection to the database and make it run) - but this is actually not what ROON recommends, as Core and the rest of the system are not separated...
... so, which way is the best for ROON?
5.
Is either one or are both options superior th CD playback... I would assume yes, as again the main problem seems to be jitter added through different processes. Now a ripped CD via dBPoweramp for example, where the CD gets re-read 100ds of times and is crosschecked on multiple plattforms, will ensure a perfect file as source. This is already a better starting point, as NO CD is free of error and besides having the transport spinning the disc I would suspect that the biggest downside is the error correction of a CD - I would believe no CD runs without error correction taking place and so the perfect rip must be better - following that logic it seems the main problem for computer based playback is keeping the perfect file free from interference on it`s way until it reaches the endpoint...
AGAIN
this seems obviously ealsily achieved by unsing Antipodes (solution 3) - so why does ROON recommend something else though?
Any help and further suggestions will be greatly appreciated,
thanks,
Christoph
1.
2.
3.
4.
5.
AGAIN
thanks,
Christoph
