Listen to that you definitely have to spend more money on analog to be better than the metronome player. the comparison refers to new devices, not used devicesTo summarize I want cd player to be close to ch precision d1.5 c1.2 at a much lower price. Getting is long way from wanting.
+ 10^ 23rd.I would say most of the hifi systems I have listened to (both short term and long term) and some systems I have owned, the best sounding ones (to my ears) were either components from the same manufacturer or a hifi system with different manufacturers that has been carefully tried and tested over a long period of time by a well respected hifi dealer / hifi consultant etc.
What I do is to record the LP or tape onto digital (DSD128 in my case), and then playback the digital file to compare with the source. Of course, the recorder is also in the equation, but in my experience, with the Tascam DA-3000, the result in DSD format is excellent. This will give you a fair comparison, because you will be comparing the different DACs with one single reference, which is the analogue source.Blanket statements -- or speculations -- about what digital playback hardware combo can match whichever analogue hardware combo (and vice versa), ignore the critical element of source material.
No matter how "good" your digital setup is, if the track / CD / SACD you're playing is FR restricted and flattened dynamically, it will sound pathetically worse than its (healthy) analogue counterpart played on a well setup Technics.
The converse applies as well, but it's rarer in my experience.
I.e., IMO expecting to draw reliable conclusions by comparing & contrasting the purported performance of digital & analogue reproduction hardware is tricky...
i an in the “system synergy” camp…
…Therefore on that note (pardon the pun), if you were to buy the CH C1.2 you would for sure need to buy the CH D1.5 connected together by the special CH Precision interconnecting cable (tried and tested by CH for the connection of these two components plus being able to obtain the CH Precision maximum sampling rate from the CD/ SACD Transporter and DAC).
If you can't afford both the C1.2 and D1.5 at the same time, you could initially just buy second hand the C1 which can be upgraded by CH or a CH Dealer to the C1.2 (at not too high cost) and buy for now a second hand the D1 (seen one online a month or so ago going for approx. US$12k) Then after say 6months to a year upgrade the C1 to the C1.2 and in a few years sell the D1 and buy a second hand D1.5 !
I think though 'bonzo75' with me referencing to my last post on the synergistic manufacturer's equipment pairings subject, in the case of the CH D1.5 and the C1.2 they were designed and built to be operated together as one in order for the user / listener to get the ultimate performance from them both especially when playing SACD.There is a very good CH 10 system here, but the owner while a CH fan preferred the Lampi Atlantic to the CH digital. While the Atlantic (a lower Lampi model) is synergistic, on paper someone would have made the decision that obviously CH digital is more synergistic. No different from when the Soulution preamp is a fantastic match to the Allnic 300n power amp and we wouldn’t have guessed it till we tried it. So while there is system synergy, there is “assumed synergy” and “actually better synergy”
Well Bonzo was brought up on Digital, looked what happened to him ..!
Systems that are optimized to extract the best from an extensive record collection may not be optimal to extract the best from a transport and dac and vice versa. Different equipment,room treatment,and cables would be chosen.
Hehe. I grew up on vinyl in my youth, but after adopting CD I never looked back. I still am exposed to vinyl in friends' systems, I very much enjoy it, but it's not for me.
Everyone is different.
We all make our choices based on our own criteria.
Likewise. I started off borrowing records from the public library. Then CDs and back to vinyl at the same time as I started streaming (2010) as I got some space for it.Yes everyone is different. Bonzo grew up on digital and switched to vinyl. You grew up on vinyl and switched to digital.
I grew up on vinyl, switched to digital for a while and then re entered the hobby with both formats. I played both and enjoyed both. As I got more serious I dropped digital to pursue vinyl at higher levels. We all make our choices based on our own criteria.
Both generate an analogue line level signal to my integrated amplifier. What's the problem?One of the many reasons why I don’t want vinyl in my system. It's hard to optimize a single system for two sources.
first you need a record collection ....Agreed.
You make is sound like the lurgy ...I still am exposed to vinyl in friends' systems, I very much enjoy it, but it's not for me.
