I normally use RTA but wanted to try REW because I'm sure it's better. However, I'm having a problem that is driving me nuts.
REW thinks that the mic signal is very low - something in the area of -89db.
I use an RME Fireface 400 (pro) sound card and the I have the input of the mic input raised to just below clipping.
The actual output in the room is reading as 90db on my Radioshack SPL meter. I've tried calibrating REW, even used the soundcard loopback (which is withing a few db of each other) and still it can't measure because the lowest peak is too low.
Any thoughts?
Any thoughts?
