Cardas Audio cables
GuidoCorona
327
35
413
Summerville (SC)
Hello Jeffy, any cable with 50 hours on it is pretty young, and so is a Clear Reflection XLR. Initially, an ICS is likely to go through some seemingly bewildering tonal girations... Closed in one moment, and trebly or harsh the next. This is fully to be expected. My experience with my current Cardas loom is that break-in continues for 350 to 450 hours of passing a signal.
While I would not call the Reflection line "warm" per se, ICs and speaker wires of this series seem to me extremely musical and graceful. I would call them neutrally extended, with a subtle glow.
Saluti, Guido
advanced101
247
176
233
I spent some time with the Cardas Clear Beyond IC. I really wanted to like it. I have compared this IC on two different Tube/ Vinyl based systems and it sounded closed in, dull, & ordinary. These cables may do better on systems that lean towards bright and hyper detailed but for me I much preferred Audience Front Row, and even Wywires Platinum. The cable had 300+ hours.
assessor43
312
192
128
Whats the difference between clear and clear beyond? I always thought clear was a very good cable.
Thieliste
751
231
265
52
I'm very tempted to demo Clear Beyond IC and SC in my system.
I know that many Thiel speaker owners in the US have used Cardas cables with success in the past.
Musicality is what i'm looking for as i don't use any tube gear yet.
Thieliste
751
231
265
52
Ok guys, did a shootout yesterday between my Gryphon VIP SC and Inakustik Reference Air LS-2404 SC.
Well there was no contest, the Inakustik got smoked by my VIP cables by a wide margin.
That's telling me that i need to try cables that are at least in the same league as my Gryphon VIP if i don't want to lose resolution, air, depth and soundstage.
I really need to try the Cardas Clear Beyond because the Clear Reflection will probably be a step back compared to my Gryphon VIP.
Any thoughts ?
Marcus
487
364
370
Any thoughts ?
Do it. You won’t be sorry. You wrote musicality is what you’re looking for, so Clear Beyond SC and IC’s even more will be a great choice.
Reactions: Thieliste
Rocoa
114
76
115
Spain
No doubt. Cardas Clear has more resolution than Clear Reflection and you will have Cardas musicality.
Thieliste
751
231
265
52
Which cable would have the most impact in the system IC or SC if you could afford to change only one ?
GSOphile
450
258
168
Your speakers are reputed to have hot tweeters, so probably the speaker cables. That's why I think the Clear Reflections would be the better choice for what I think I'd be trying to achieve were I in your place.
Gregadd
1,396
1,270
Metro DC
Generally speaking the smaller the signal the most critical the cable.
Gregadd
1,396
1,270
Metro DC
The opposite point of view endorsed by many would be power cables having the most influence on system SQ.
Certainly for me pc had a dramatic effect. I attributed that to progressing from generic to specialty cords.
spearl8
17
10
8
34
I recently got a Cardas Clear Ethernet and their myrtle wood blocks to go under my DAC and preamp and their myrtle wood notched blocks to lift my speaker cables. I was expecting 0 to little difference against my Shunyata venom Ethernet and no lifters. Boy was I wrong! Instantly noticed more detail, crisper high frequencies, deeper bass, and a more pleasing sound. The wood blocks smell nice too out of the package :)
Thieliste
751
231
265
52
Hi guys, i received my Clear Beyond IC and SC just started the cooking:p
Cellcbern
1,055
578
445
69
Washington, DC
I had the same experience with the Clear Beyond power cord, and generally have not heard any Cardas cables that I wanted to keep in my system.
Thieliste
751
231
265
52
Only 30 hours into the burn in process all i can say i that Clear Beyond are by far the best cables i've ever heard in my whole life so far.
Than again what works for me might not work for you because as all of you guys know this is all system dependent.
The synergy between Clear Beyond cables and my Thiel speakers is just mind blowing.
All i can recommend if you plan to purchase expensive cables, always try then in your system otherwise you could well be very disappointed.
Reactions: RnRmf
Thieliste
751
231
265
52
Hi guys, i'm 176 hours into the break in.
When do you guys consider they are mostly broken in is it 300 hours or more ?
Kcin
545
593
275
Canada
I am not certain on break- in time. My experience with out of the box cables was they were unlistenable.
Based on what I heard elsewhere, I tried them again - this time 3 days on the Audiodharma cable cooker. Sonic bliss.
I would say that 300hrs is close to fully baked.
Rocoa
114
76
115
Spain
You culd perceive sound compression during some time of the burn in process.
more than 300 hours perhaps.
