is there any synergy or contraindication adding Daiza platform between centerstage2 and existing shelving?
Good question as I don't know the answer except to say they might be competing technologies and self defeating to use both
For me I would use one or the other. Joe, the manufacturer always states that all existing tweaks should be removed before using Center Stage
Centre Stage 3 out yet?
Except the re-settling time makes these comparisons very difficult to do.
Resettling with CS2 is much quicker
I have spoken to people who followed the strict 10 day settling period. They followed the prescribed process, did their evaluations, heard what they heard and then switched over to more rapid A/B testing and heard the same or very similar results. Perhaps after the initial settling period the footers require less time to return to a “good” state.
Is this settling process well understood?
I'm in the (apparent?) minority who encountered minimal change to the effect produced by CS2 1.0 footers over the course of the prescribed break-in period. I placed them under a heavy amp, a much lighter phono stage, and it's PSU that falls somewhere in between. When I AB'd CS2 vs direct-on-rack at time 0 then again at time 14 days, the delta was roughly the same or at least more nuanced than my medium term audio memory.
I can put the CS2 feet around the stock feet but very close to each other. Is that gonna reduce the 1.5 effectiveness?First off congrats on your purchase bt a few things
1. The Center Stage feet are never placed under the stock feet but rather somewhere around each stock foot
2.I am not too familiar with Thrax amps but a few points
The 1.5's are designed for large and very heavy components such as amplifiers over 100 pounds but certainly a stock foot of over 1.0 inch in height would mandate 1.5's being used however my guess is that a set of 1.5's are just too big for your amp.
I would have suggested you consider using 1.0's and not 1.5's and impossible to remove the large rubber stock feet
HTH
