Will the rubber feet reduce the energy transfer? I think i have read somewhere Joe said that CS2 works even through a layer.If not, placing the four 1.5’s as you said will be fine. I didn’t realize the weight of your amp so yes 1.5 is a good choice
Hi ozzyI have CM 1.0's under my Lumin X1 and my Carver M350 tube mono blocks. I was thinking of getting a set to go under my Audioquest Niagara 7000 (90lb.)but I haven't seen any comments about placing the CM footers under power conditioners. Would the Niagara benefit?
ozzy
Hi HiekumWill the rubber feet reduce the energy transfer? I think i have read somewhere Joe said that CS2 works even through a layer.
I have a client that has Center Stage under his NiagaraI have CM 1.0's under my Lumin X1 and my Carver M350 tube mono blocks. I was thinking of getting a set to go under my Audioquest Niagara 7000 (90lb.)but I haven't seen any comments about placing the CM footers under power conditioners. Would the Niagara benefit?
ozzy
CS footers under power conditioners and grounding devises? Amazing!I not only using CS2 1.0 under my Core Power 1800 with excellent result. I also use them under my Entreq ground boxes with excellent result as well. Those Entreq ground boxes are passive in nature and all they do are to absorb dirty ground as much and as quick as possible from connected components. May be the mineral mixture are dancing around inside after being feed with all those ground and need CMS to keep them behave.
Never have enough money to buy CMS footers for EVERY single box among the 2-ch system. Now come the LS....
I recently ran a test and just removed my CS2s from resting on my symposium iso platform to now resting on the rack wood shelf, I much prefer sound without the symposium which surprised me. The electronic piece the test was performed on was a CD player.I'm not sure anymore but I think I read somewhere that it's recommended to place the CS2 footers rather on a wooden and not on a metal surface. I'm very interested in trying the CS2 in my system, but it's just that currently I'm using a Symposium Isis rack plus Ultra platforms and there is always a metal surface.
The big question is if the CS2 footers are compatible with the Symposium rack and platforms? Maybe the additional Ultra platforms wouldn't be needed anymore with the CS2.
And if it makes a difference if I put a wooden platform between CS2 and metal rack?
Thanks, Michael
Joe recommends that all tweaks be removed wren you use his feet so I understand your findingsI recently ran a test and just removed my CS2s from resting on my symposium iso platform to now resting on the rack wood shelf, I much prefer sound without the symposium which surprised me. The electronic piece the test was performed on was a CD player.
Many thanks for your test and your reply, that's what I thought.I recently ran a test and just removed my CS2s from resting on my symposium iso platform to now resting on the rack wood shelf, I much prefer sound without the symposium which surprised me. The electronic piece the test was performed on was a CD player.
Thanks, Steve, about the clarification of Joe's recommendation. That explains my misleading experience.Joe recommends that all tweaks be removed wren you use his feet so I understand your findings
