Mine looks differentView attachment 73342
Um not really. Perforations everywhere
Front of Extreme is on left
So now we are confronted with different versions of Extremes ?
I'd like to know how many versions are out there. Based on the exacting nature of Extreme I would think there is a desired version....
Hi KingsruleView attachment 73342
You need to play musicFor the foot break, do you have to play music through the DAC or can it be turned off?
That’s an interesting question as I’m going to defer to Joe. My impression however is that the feet settle quicker if you play music through your speakersIt is ok if I leave the DAC playing music, but I turn off pre amp and amp?
It is important that you measure the height of the Mephisto's feet. From the pictures they seem quite tall and almost certainly that the 1.0 with its 25 mm height would not be enough. The 1.5 is 38mm.I’m interested in getting CS 2 feet for use with my Mephisto amp. Which size do I need? Probably 1.5? I understand, that I should put the feet next to the stock feet and not directly under them. Is that correct?
Thanks in advance.
Aziz
Unfortunately Mephisto‘s feet are almost 50mm. I’ll have to check if they can be removed.It is important that you measure the height of the Mephisto's feet. From the pictures they seem quite tall and almost certainly that the 1.0 with its 25 mm height would not be enough. The 1.5 is 38mm.
If you check my thread under Gryphon titled "Mephisto bottom end" I show pics of the bottom of the Mephisto and discuss removing the feet.Unfortunately Mephisto‘s feet are almost 50mm. I’ll have to check if they can be removed.
Hi Joe,Hi micro 13
I checked out the Symposium website. Let me say they are a long respected company which produces high quality products. Having said this, our companies use different materials in our construction processes and I think therein lies the reason for the performance issue you are experiencing. In my experience, CS2 products are not compatible with suspended stainless steel shelves.
Again, Symposium is a fine company. We simply differ in approach and results. In order to experience the performance potential of CS2 you would need a buffer between the SS rack shelves and the aluminum feet. Folding the silk bags the CS2 come with and slotting them under the CS2 feet should work, I think. I wish it were not the case, but I don't know of any way around it.
I sincerely hope this helps.
All the Best
Joe
Hi MichaelHi Joe,
many thanks for your considerations, I already feared that CMS and Symposium are not compatible.
Probably in the next two weeks I'm getting the CS2 1.5, I'll try your advice with the folded silk bags and report back. I also thought to try an Ikea bamboo cutting board as a buffer, what do you think about that?
Regarding the incompatibility to suspended stainless steel shelves should I also remove the Rollerblock modules from the rack's columns?
Thanks and all the best
Michael
HuskJoe, Are your feet compatible with using them on top of the Stacore isolation platforms?
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
