Series 10 of CH Precision was announced in Munich Show in 2019. First there were L10 preamp and M10 power amp. The original M10 was a huge box, later it was split into two boxes for easier handling. I listened to L10 and M10 on several occasions and was very impressed by their performance. There was a waiting list for them.
P10 was finally demonstrated in Munich Show in 2023, I was there to audition the difference between P1 and P10, also P10 and P10 mono was demonstrated. The difference between P1 and P10 was huge and there was incremental gain from P10 to P10 mono. I placed an order for P10 on the spot.
The first batch of P10 was delivered to Hong Kong at the end of September. My P10 was delivered yesterday and the local agent helped to setup the phono. P10 is a complicated device with multiple modes and different curves. It is much better for the agent to setup for you.
The first cartridge mounted was Lyra Altas Lambda SL and tonearm was Graham Elite 12in, The resolution was very high, the sound was smooth and dynamic. Bass was strong and layered. Although I listened to P10 before but was still very stocked by its performance. The cartridge was later changed to Koetsu Tigereye Diamond and Etsuro Gold, P10 clearly presented the sonic characters of these cartridges. There is no audible character with this phono, it just amplifies what is coming from cartridge.
P10 is clearly the best phonostage I have heard by some margin. I know a buyer in Hong Kong has ordered two P10 for mono run. They will be installed in these few days. It will be interesting to know how they sounds.
i am glad to be able to hear and see the breakthrough in vinyl playback. P10 really takes it to another level.
