Collecting names - tube preamps with onboard tube MM phono stages
Tangram
211
282
70
60
I have a simple system with just a single source, a turntable with one tonearm. I currently use an E.A.R. Yoshino 868pl preamp which has a built-in phono stage that uses four tubes - all the same - in total. I have an Allnic SUT connected to the E.A.R.’s MM input. I really like the simplicity and reliability of this setup. However, I’m curious about other one-box tubed preamp/phono pres that may elevate the overall sound of my setup.
I’d like to do some research on what else is out there so if you have any names you can pass on, I’m all ears (pun intended.) I know of a few options, like the Miyajima EC-5, but happy to hear about others. Please note that I do not need an active MC circuit, even though the E.A.R. has one (the Allnic SUT is far superior.) I also want a one-box solution, so no external power supply.
DasguteOhr
2,445
2,623
645
Germany
If you just want to enjoy only LP, there's no way around Thöress preamp 6 phono inputs. 5 with internal transformers 65db gain can be very flexibly adjusted (ohm)and 1 input MM 45db gain for your allnic sut. If you want, you can influence the Riaa equalization with three rotary controls. For example, making a bad recording sound better. Read the description maybe something for you, last price i know 9.5 k€
Reactions: Artnet and Tangram
Republicoftexas69
Tangram
211
282
70
60
View attachment 119591 View attachment 119592
I’m looking for a preamp with a built-in phono preamp. I do see, however, that Thoress makes one. Thanks.
Tangram
211
282
70
60
Reactions: Republicoftexas69
PierreB
242
318
970
Rimouski, Quebec
Modwright LS100
DasguteOhr
2,445
2,623
645
Germany
No problem another version of this available. That preamp has no adjustment of the riaa or for mono cartridge inputs. 4 line stage inputs+3 phono inputs and 2 outputs
Tangram
211
282
70
60
Perfect. Other than the two extra phono inputs that’s exactly what I have in mind. Will it beat the E.A.R.? I have a local Thoress dealer so hopefully I can find that out for myself.
Reactions: DasguteOhr
Republicoftexas69
Thanks! Very interesting. This isn’t a brand I’ve seen in Canada but I’ll investigate.
Constantine at Atelier-13 can help you. He may know who in Canada.
Reactions: Tangram
Gregm
532
383
155
France
Apart from the Thores above, I can thoroughly recommend the CAT pre. By used if necessary, you can happily upgrade the tubes to your liking if you so wish. The rest doesn't need any maintenance
Very crisp and pleasantly resolving, with sought-after, tubes', explosive dynamics.
Similarly with the EAR yoshino 968(? something like that)
Reactions: Tangram
tima
5,863
6,935
1,400
the Upper Midwest
I used its big brother the MP-1 for several years. Top quality build, top quality sound.
Reactions: Tangram
AudioHR
231
210
90
71
High River, Alberta Canada
Back in the day I was very pleased with the Audible Illusions Modulus 3b. I see it has been updated and apparently it is still being produced.
I have no idea how it might compare with an E.A.R or a Thoress perhaps it has had its day in the sun.
Reactions: mtemur and Tangram
Tangram
211
282
70
60
Thanks everyone for chiming in with options. There are a number of new-to-me-names, which was what I was hoping for. Now I just need to line up a couple to try out in my system. In the meantime, I’m comparing some Siemens and Amperex tubes to see if I have an obvious preference between the two.
Tangram
211
282
70
60
I’ve been trying out a Miyajima EC-5. Totally different sonic character. In car terms, the EAR is a Cadillac, whereas the Miyajima is a Lotus. I prefer a cushy ride.
Salectric
381
501
998
If you’re open to used vintage gear, one of the older ARC preamps—-SP3, SP6 or SP8—or a Conrad Johnson PV5 would do nicely.
Tangram
211
282
70
60
Thanks for the suggestions, but I’m set on a line stage with onboard phono.
Salectric
381
501
998
The ARC and CJ models are full function preamps—-MM phono and line.
For newly manufactured preamps, the Audio Note M3, M5, M6 and M8 are available with MM phono and linestage in a single chassis.
