Can someone find me a good article on the difference between standard pre-amps, passive pre-amps and linestage amps? I think I understand it, but am not quite sure either.
Thank you so much!
Thank you so much!
I can't recall an article off the top of my head, but here's a very brief synopsis:
Historically, a standard preamp was an active one that included a phono stage too. In this instance, active means that it contains one or more powered amplifying devices (tubes, transistors, etc.).
A passive preamp is essentially just an input selector and an attenuator. You can't make something louder with it, only quieter, so the sources must have enough umph to drive your power amps.
A line stage is a preamp (passive or active) without a built-in phono stage, which is probably most of them these days. Almost by definition, most (all?) passive preamps are line stages.
Hope this helps!
Linestages can also have both passive and active as the Ensemble line stage.
Problem with the passive devices as I understand it, is that frequency response changes as a function of the volume setting
i read a survey somewhere that 99% of audiophiles that owned passive preamps were also vegetarians. Apparently they don’t like any meat on the bones of their music either.
I read a survey somewhere that 99% of audiophiles that owned passive preamps were also vegetarians. Apparently they don’t like any meat on the bones of their music either.
John, seriously, you still have the Pioneer integrated amp right? If you decide to get into the separates, you really need a full function preamp meaning one that has a phono stage built in unless you decide to break out the separates into one more piece and buy a separate phono stage. If you are on a tight budget, I can’t recommend the Yamaha C2a high enough if you can find one. The line stage sounds really, really good and the phono stage sounds better than the ARC PH-3SE that I owned. It can handle low output MC cartridges and it’s quiet. I can’t see me ever selling mine because what they bring is nowhere near what they are worth in terms of their sound quality.
Do I have these assumptions correct:
Passive Pre-amp: No tubes, no transisters. Only has source selection and volume attenuator?
Linestage pre-amp: Tubes or transisters. No built-in phono amp?
Standard pre-amp: Tubes or transistors WITH built-in phono amp?
You got it (modulo the hybrid models mentioned above)!
Sweet!
How does one make the choice between a Passive unit and a Linestage?
Simple, listen for dynamics I've yet to hear a passive that could reproduce dynamics like a real linestage Passive attenuators have to me been one of those products that sounds "perfect" in theory but less than perfect in reality.
To solve the problem, you can use a buffered passive preamp. The buffer is still an active circuit using tubes or transistors, but it has no voltage gain - it only interposes itself to make a low impedance into a high impedance, or vice versa.
The First Watt B1 Buffer Preamp can be bought assembled or you can get the DIY plans.
Some of you may remember Aunt Corey'sHomemade BufferedPassivePreamplifier plans published in Stereophile back in 1995.
