I was making a general statement about people on this forum who have proclaimed in the past that analog distortions help analog sound good.
My memory:
I've seen quite a few speculations that some people like a dose of second order harmonic distortion. The people making the speculations don't usually say "I'm addicted to that added distortion."
What flaws outside of surface noise are you referring to?
Some everyday flaws
Compromised frequency response to fit the limitations of the lathe, the final LP and the range of turntables and cartridges on which LP might be played,
gross distortion in peaks,
Constant surface noise,
loud clicks and pops at specific locations,
static which produced directly audible results and attracted dust,
warped records,
locked grooves,
off center holes,
sensitivity to vibration,
the difficulty of getting rid of hum and noise even with a relatively high output MM cartridge.
Messing with the turntable, arm and cartridge to get it set up right didn't appeal to me either. Cleaning records didn't make listening to music any better either.
Flaws in pressings made some great performances unlistenable.
Some examples of flaws that mattered a lot:
A recording of the Beethoven Archduke Piano trio by the Stern-Istomin-Rose trio got rave reviews so i bought a copy. It had a bad flaw in the first couple of minutes that made it unlistenable. I returned that copy to the store and got another. Same flaw. I never got to listen to that LP because the entire production run in the stores at that time had the same flaw. The CD sounds great. I just wish that I had been listening to that performance for 35-40 years rather than 15 years.
My very favorite performance of the Beethoven Violin Concerto was by Grumiaux and Galliera on Philips. The LP had a very warm sound by the surface noise was so high that the LP no more than 10-15 dB of dynamic range. The CD doesn't have the extreme warmth but it has normal dynamic range. Much nicer to listen to.
The Fruebeck de Burgos recording of the de Falla: Three Cornered hat on EMI remains my overwhelming favorite for that work. The LP had gross distortion at the beginning where a chorus shouts. The remastered CD from around 2001 is free of that distortion and sounds cleaner throughout.
The Fruebeck de Burgos recording of Orff's Carmina Burana on an EMI LP had gross distortion in peaks through the performance. The remastered CD from 2001 is free of these distortions.
An RCA LP of the best Glenn Miller numbers had such wow and flutter that I could not stand to listen to it. The CD does not have the same flaws. (This material originated on 78s so this wasn't a question of fidelity. Just competence which you could not rely on in the LP era.)
What components made up your LP playback system (table, arm, cartridge, and phono section)?
Turntables - a cheap Garrard, a Thorens TD-150 with stock arm and then with a fancy arm, a Sony PS-1800 turntable.
Cartridges - ? to start, a Grado somewhere in the sequence, a Shure M-91, an ADC XLM (?) (roughly a Shure V-15 II equivalent), some kind of Audio Technica.
Phono stages - Dynaco SCA 35, JBL SA-600 or 660, Yamaha receiver, PS Audio 4.6 pre-amp.
There may have been more in each category.
The perfect harmony bit was a joke Bill.
And so was my response.
Bill
