earlier versions of LP sound better than modern version?
chris9
1
74
I will be purchasing some jazz and blue LPs to fill my LP stock. Some audiophiles say older versions sound better and thus more expensive. Is it true?
I will be buying some LPs of Miles Davis and John Coltrane's. Do their earlier version LPs sound better than modern day versions?
For Miles Davis, I am looking for: Kind of Blue
For John Coltrane, Blue Train.
With thanks
KOB - Mofi , AP UHQR
BT - Music matters , AP
I would do a few things to help you find the best pressings
for one look myles Astor of audionirvana hope thats spelled close enough. He is a walking amazing talent on analog sources. Gary koh as well.
also there are non audiophile you tube videos
when I was looking for good pink floyd that guy was great. He said why and described why then showed markings and all you need to look them up.
i hope this helps you.
The major issue with getting an original pressing is that there are almost none that are in mint condition, something you can easily get with the reissues listed above. So regardless of the sound quality differences in mint versions of original vs. reissue, the originals that you can buy are not going to be mint unless you have infinite patience and close to infinite money.
One important point about the KOB issue. When originally released there was a speed error in the playback of one side (or one cut). That made the side or cut too fast or too slow (someone put in the correct details.) As I remember it was later discovered and when Classic Records did their audiophile reissue 30 years ago, they did correct the problem (I remember they had two versions on the reissue, one at the original speed and one at the corrected speed - IIRC maybe 1 or 2% different).
Larry
Reactions: Tango and Alrainbow
