Hi Amir,
here is an excerpt from a press release/article on D'Agostino's new venture:
Howdy!
The issue I am trying to help them resolve is that the only mention I ever see is that picture. And there, there is no scale. This is especially important as they say in the press release given the fact that high-end amp is synonymous with huge enclosures.
D'Agostino says that while 'most 300-watt monoblocs are the size of an air conditioner
Now they are going overboard
. An Air Conditioner? Here is the Mark Levinson 532 which is a dual mono, *400* watt amp:
http://www.marklevinson.com/ProductDetails.aspx?prdid=2
"Width: 17.5 inch" (rack size)
"Height: 8.75" (without feet)
That is not the size of an Air Conditioner. In my quick look, most Window A/Cs are 15x16 inches which is twice as tall. That said, the D'Abostino is half the size.
, the Momentum fits easily into an equipment rack' – in fact it stands just 10cm tall, is 32cm wide and 45cm deep.
Per above, the ML also fits in the rack except that it takes more height.
And along with its low 1W standby power consumption, the amplifier has been designed to run cooler than conventional designs, thanks to the use of copper for the heatsinks, and ventures instead of the more usual fins.
Now this is puzzling to me. Being the nosy type
, at CES I put my hand on both running and non-running (but powered) units. They were all running quite hot. I used to repair Audio equipment for a living and our test of whether something was wrong was if a device ran so hot that if you put your hands on it or its heatsink, you couldn't keep it there. The D'Agostino was pretty close to that including the unit that was powered but not connected otherwise. If it has a standby mode, the one on display must not have had that activated.
With amps, I like to see a reliability track record especially if someone attempts to make them small as they have. I suspect these amps would do fine but I like to see a bit of mileage on it before jumping in with both feet at such high cost.
These have a 19mm opening top and bottom, narrowing to around 12mm in the centre, the expansion of the hot air at the upper opening drawing cool air in at the bottom.
I like that. It would have been much cheaper to use a drill and have the hole be the same size all the way through but likely would not have as good an air flow.
The chassis is machined from a solid billet of aluminium, and the amplifier is assembled from the base so no fasteners are in evidence on the front, back, sides or top-plate.
There we go with wasteful design again
. I hope that design doesn't make it a pain to troubleshoot and repair. Don't like to just see the bottom of PC boards and not the components on top.
Following soon will be a matching Momentum preamplifier, said to be 'a unique product that combines the functions of a traditional analogue preamplifier with a digital media server'.
I see a nice trend with pre-amps with DACs in them. This is a badly needed product to help bridge people from analog/digital-transports to media servers.
