had anybody in the forum used pc's built by this company?
I am looking to buy a music server, to play PCM files and some DSD and still debating if I will go with music servers like the Wyred 4 Sound MS-2 or Aurender X100 and the likes..
then somebody suggested a fanless pc based server as it can offer more functionality.. is there any advantage in going with Aurender over going with a purpose built pc?
been looking at this Streacom Music Server model from endpcnoise.com
Streacom Music Server - $ 3,219.00 (with Linear power supply upgrade) - info from their website
Fanless, Noiseless, Dustless
This is the fanless music server you've been waiting for!
Intel Z97 Chipset
We have created this beautiful music server, featuring computer audiophile level power filters specifically for exemplary audio playback. Our audio expertise and extensive knowledge of the perfect quiet PC have come together to create a powerful yet silent music server that produces flawless, high-definition audio playback, and can fit into any listening room. This music server is a must for any audiophile looking for the cleanest sound quality available, without the distraction of computer noise (physical noise or electrical ripple).
Exclusive Audiophile Music Server
In addition to the fanless music server itself, high-end audiophile components have been included in order to make this into a true music server. We have configured this music server with the best options in USB and SATA noise filtration ensuring the best possible sound, with options for an external linear PSU for even better performance. SOtM tX-USBexp Computer Audiophile PCIe to USB Audio Card
The SOtM tX-USBexp is an advanced audiophile PCIe to USB audio card like no other. This audio card has a unique design incorporating an ULNR(Ultra low noise regulator) for digital, clock, USB power circuit. Power input noise filters. PCI express slot noise filters. Extremely Low Jitter clock. Active noise canceller for clock power. You can also use the audio card's external power connector to bypass your computers internal power supply and feed the card directly with the HDPlex Linear PSU for an additional boost in performance. Audiophile SOtM In-Line SATA Power Noise Filter MKIII
We default our Fanless Music Server with the SOtM In-Line SATA Power Noise Filter MKIII. This device has a unique design incorporating individual 12V, 5V, and 3.3V RF noise and ripple filters to improve the sound quality in your Music Server. We recommend these for use with all SATA drives, including Optical Drives. The MKIII has an Improved noise filter section compared to MKI and MKII, and SATA the data lines no longer route through the filter to improve compatibility. We recommend that you put your data storage drive in an external enclosure to minimize electrical and physical noise in your Music Server.
HDPlex Linear 100w PSUAlong with the SOtM SATA Filters and SOtM PCIe USB Card, the HDPlex 100w Audophile Linear PSU is highly recommended for the true audiophile. Linear PSUs are much quieter than standard Switchmode Power Supplies, which can cause distortion to your audio, as well help reduce ripple and general electrical noise output for your music server.
Pure Sine Wave UPSPure Sine Wave UPS We default our Music Servers with a Pure Sine Wave UPS to get the cleanest power possible into your entire PC, and external devices. In order to ensure the best sound quality available, it is important to make sure that your entire power chain is clean, and a Pure Sine Wave UPS provides clean power to all devices connected to it.
Fanless Music Server Features
This Mini Fanless Music Server is an audio component size Micro ATX based PC with a HiFi Design and a truly silent passive cooling. With its miniscule dimensions and pure aluminum design, the Streacom Fanless Music Server fits perfectly into your professional HiFi environment. Its unique heatsinks it cool down passively resulting in a strong performance without any fan noise.
•Intel® Socket 1150 i7 Processor
•Up to 32 GB of DDR3 Memory
•Up to 5 Quiet Hard Drives
•Completely Fanless
•Zero Noise!
•Zero Dust!
•Configured with the SOtM tX-USBexp Audiophile PCIe to USB Audio Card
•Configured with the SOtM In-Line SATA Power Noise Filters
•Configured a Pure Sine Wave UPS
•Configured an External Hard Drive for Data Storage
•Support for the Linear HDPlex 100w External PSU
Streacom FC10 Alpha Mini ITX Fanless PC
Streacom FC10 Alpha Dimensions
•Width: 17.1" (435mm)
•Depth: 12.5" (319mm)
•Height: 3.9" (100mm)
•Weight starting at: 19lbs
Front/Side Ports
•2 x USB 3.0
Streacom FC10 Alpha PC Front Ports
Music Server Core Components
Intel CPU logoLGA1150 Intel® 4th Generation Processor Ready This motherboard supports Intel® 4th generation i7 processors, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great onboard graphics performance. Intel® 4th generation processors are among the most powerful and energy efficient CPUs in the world.
Silent Disk DrivesSilent Disk Drives All of our Quiet Music Serves are defaulted with a dead silent, extremely fast, and ultra reliable Samsung SSD (Solid State Disk) for the Operating System. For anyone requiring ultimate performance and silence, we recommend one of the ground breaking Intel 750 series PCIe based NVMe SSDs, which has write speeds that are nearly twice as fast, and read speeds that are about four times as fast as a standard SATA3 based SSD.
Asus Motherboard logoQuality Asus Motherboard We feature the latest ASUS® motherboards in our quiet systems. ASUS® is the world's best selling and most award winning motherboard manufacture. They provide supreme reliability, top notch cutting edge features and excellent manufacture support. Our motherboards contain fanless heatsinks and heatpipes to effectively cool the chipset heatsink and voltage regulators, without the use of noisy fans.
High Quality Memory This PC comes with high quality Kingston® memory. We use Kingston® memory because it is highly reliable and features a lifetime warranty. This Fanless Music Server has options for up to 32GB of RAM for those desiring ultimate performance!
Streacom Mini Music Server Motherboard
•Intel® Socket 1150 for 4th/5th Generation Processors
•Max. 32 GB, DDR3
•Intel®Z97 Chipset
• 1 x HDMI ports | 1 x DVI-D | 1 x VGA
•1 x Sata Express Port
•1 x M.2 Socket 3 with M Key
•6 x USB 2.0 (2 at back panel)
•8 x USB 3.0 (4 at back panel)
•6 x SATA 6.0 Gb/s ports
•8-Channel High Definition Audio
•ATX Form Factor
We don't just choose quieter parts, we choose the quietest, best performing parts available and assemble them cleanly to optimize airflow and minimize the slightest vibration. We don't just replace one or two parts in our system with relatively quiet components, we replace each component with the quietest part available.
In addition to silent parts our systems are built with pride for many years of use. From start to finish, we anticipate, research, and test each system for maximum compatibility and performance; all while being absolutely silent. You will be amazed at how quiet our systems are!
They have another model above this..
and my wishlist also include I2S connectivity (to my PS Audio Direct Stream Dac).. hoping to upgrade to Lampi, but that would be a 2016 project as I have another major upgrade in the work
Intel Z97 Chipset
•Completely Fanless
•Zero Noise!
•Zero Dust!
Front/Side Ports
•2 x USB 3.0
•Max. 32 GB, DDR3
•Intel®Z97 Chipset
•ATX Form Factor
