Hi all again.
In an attempt to address the shortcomings of using a "live vinyl LP" as the source for the "with and without Entreq" comparisons, I have been very hard at work this past 36 hours producing "digital" comparisons instead. Although I accept the criticism in general that vinyl sound will always vary from play to play, I will always maintain that in this particular case those variances did not substantially effect the actual sonic result in the case where critical ears are used to make judgements (I have never heard the playback of a given vinyl LP on a good quality system vary to anywhere near the extent demonstrated in those earlier Entreq comparison files, despite comments to the contrary by other parties). Neverthless, this "digital" comparison ostensibly eliminates those potential variables.
It has been a
huge amount of work to do this second comparison, including spending some hours completely re-configuring my workstation, choosing and preparing the source files, etc to be able to complete this test - I effectively had to re-cable it and make a large number of configuration changes to enable it to record directly from the analogue output produced from a 24 bit digital source (my system was built to transcribe from analogue - not from digital. Not that it cannot do it - of course it can - but it is not set-up to do that sort of stuff on a day to day basis because that is not what I do). So I hope this work is appreciated as it was VERY time consuming - not just the work itself but preparing the files for upload, documenting them and uploading them on my Australian Mickey Mouse internet connection.
I have included a "notes.txt" file in the upload so there is no real need to clutter this post and thread with the specifics. But it contains the acknowledgements of (and links to) the source material and also contains listening "tips" so that inexperienced and / or novice listeners can more easily "tune in" to what they need to listen for in order to hear the differences. As with any comparisons, the higher quality and more resolving the playback system and the more developed your listening skills, the more obvious the differences between the Entreq / No Entreq files will become. There will be some listeners here who I already know will "breeze" through these comparisons (three of them excluding myself have already previously contributed to this thread) and some listeners who I suspect won't hear a difference at all (I really have to get this bit off my chest - perhaps less time spent sitting in front of computer screens and obsessing with measurements, audio stats and FFT screens and more time spent actually listening critically may contribute to improved listening skills...just a suggestion).
One thing I will add to this post that was only briefly touched on in the enclosed notes.txt. This test was actually quite enlightening to me (from a measurement perspective no less!!) because this time around there was a quantifiable difference in the noise floors - with and without the Entreq box connected. This is where the digital test shines over the LP test because this time around I could actually feed pure digital "zeros" in a 24 bit file from a 24 bit DAC and then record the corresponding output. Previously I was not recording pure digital "silence". This time I was.
Below are two interesting screen shots showing the sound of "digital silence" as recorded from the DAC playing back 24 bits of nothingness:
Without the Entreq box connected:
And with the Entreq box connected:
I will just close by saying I won't be doing any more comparisons. It is extremely time consuming and exhausting plus all this endless typing and keyboard work is aggravating my chronic pain...I have a cat to feed and housework to do
Apart from that I am not really keen on continually connecting and disconnecting the Entreq box. I don't really think the connectors are built to withstand such heavy duty use.
But I hope these comparisons are useful. Bottom line is this. If you genuinely cannot hear the differences between these digital comparison files then there is no further need for you to consider Entreq products. If you can hear the differences then in my opinion what you are hearing is typical of what these products can achieve when you install them in a system used for real-time critical listening. Remember too that these tests were performed just with the basic Minimus box, however the cable is a few up in the range (it is their top-of-the-line copper cable).
Being extremely critical, although the files "with Entreq" are closer in sound to the input files than the files "without Entreq", the "Entreq" files in my opinion are a little bit less focussed - perhaps they are a bit too "soft" sounding whereas the files without Entreq go too far in the "metallic / hard sounding" direction that typifies that "16 bit CD sound" most of us grew to hate in the 1980s. Based upon my previous experiences demoing Entreq equipment, however, the silver boxes would address this minor shortcoming, though it is at the expense of musical "warmth" (even Entreq say that themselves). Also, unfortunately I was unable to use a very high quality cable between the DAC output and the ADC input. Normally I use Wireworld Reference cabling and higher end Audioquest cables but I did not have anything high quality on hand so had to use a typical electronics store cable. That in itself will very slightly soften and de-focus the sound compared to something like a Wireworld or Audioquest. Still, that cable was used for every single test so again the only difference is the Entreq box. I would have loved to use a Wireworld or Audioquest cable but I certainly wasn't going to spend $500 just to make a point. I could buy another Entreq cable or base level box for that same money!!
Oh, and for the sake of completeness, in these digital comparisons, the Entreq box was connected to an un-used SPDIF RCA output jack residing on the DAC card from which I was recording. In my experience if used with source equipment equipped with both analogue or digital RCA outputs, it does not matter a whole lot which connector you use. With my Rega CD player, for example, I will be using the Entreq box connected to the SPDIF jack since the analogue RCAs are obviously being used to transmit the analogue out to the amplifer.
