A late visit from Santa, eh Barry?
Excellent news
If i EVER get my system fully running, I'm sure to look at it
Excellent news
An Olympus Tellus arrived chez Barry 2013's late last Friday afternoon. The dealer loaded the Olympus and its accompanying large box separately into the car for us. (...)
Excellent news
Can I ask you what are the dimensions and weight of the Tellus?
Excellent news
Yes of course.
The Olympus itself is 46kgs and it is W40xH20xD50 cms.
Not sure of the figs for when it is boxed but the box itself is sturdy and heavy so as to protect the ground box.
The mains earth lead is effectively a mandatory buy.
An Olympus Tellus arrived chez Barry 2013's late last Friday afternoon. The dealer loaded the Olympus and its accompanying large box separately into the car for us. The wisdom of that became fully apparent when we got home. The Olympus itself is a genuine two man lift, unless you are of the piano mover physique, and the box is quite heavy and awkward so I hate to think what it would have been like trying to carry them both together.
It has replaced an Atlantis Tellus, a Silver Tellus and two Silver Minimus and freeded up a shelf in the rack in the process.It came with an Apollo mains earth lead so scope for a further upgrade to an Atlantis.
Pardon the logistics preamble but if you do get one and install it yourself you will know in advance what is involved.
Put it in the rack and hooked up all the earth cables early evening and let it settle in before any serious listening so can't really report any immediate findings. But approaching midnight played the Dire Straits Anniversary SACD of Brothers in Arms. What a revelation. The opening track "So Far Away" had a visceral quality I was quite unprepared for. The sound came out of a totally silent background with an attack and bass power I have never experienced before in my system and the vocals in the subsequent tracks were so much more distinct. Against my better judgement I played it a second time and it was really quite magical but at 1.30am I judged it was time for bed.
The following day I contented myself with the MD 109 FM tuner and a newly acquired BIS SACD of Mozarts Piano Concertos Nos 20 and 27 with Ronald Brautigan and Die Kolner Academie. With the Olympus the piano has a new tonal density and convincing integrity of sound. Violins have greater impact and attack without any associated harshness which is particularly evident in the higher registers.Bass is fuller but perfectly controlled. Overall the sound is darker but not in anyway unnatural or oppressive, just right sounding.
It's probably pretty well there in terms of burning in and settling in my system and I have not yet played any vinyl or many CDs and SACDs so a range of pleasures to come.
At this stage though I am delighted with the Olympus. It has genuinely lived up to Per Oloff;s description of its sonic qualities on the Entreq site. A game changer for my system. Has taken it to new heights of sound quality whilst retaining all the musicality and naturalness of the sound across all frequencies.
A wonderful start to my New Year!
PS
Full details of my system are on my profile.
Not quite microstrip.
In addition to the Olympus I still have an Entreq Poseidon and two Silver Tellus. The former is three self contained Olympus Minimus boxes and is used to ground the negative speaker terminals on my amp and speakers and the amp itself. The former application requires separate or self contained boxes and is very effective in mine and other systems. The two Silver Tellus are used to earth the sources the Entreq three shelf Athena Rack.
The Olympus Tellus is the top of the range grounding box with seven grounding terminals one of which is a dedicated copper grounding post for the mains earth lead. All the sources are grounded to one of the boxes via spare inputs and the Entreq Apollo interconnects and Challenger speaker cables also have separate ground leads to one of the terminals on the box. Six of those terminals have the Everest grounding posts. See my earlier posts on this thread.
Hope that is clear and should you take a look at the official Entreq site it will all being well make it easier to digest.
Thanks! Now I am really confused! I went through the site, but could not see a logic in the way the products should be used.
My fault I am sure.
Let me try again.
The raison d'etre of Entreq is signal grounding principally for amps and sources and there is a range of earth leads of different qualities and price. Since I started down this road the range of products has expanded and were I now starting from scratch I would do it differently, more expensively initially but more cost effectively.
I would now start with the Olympus which will enable you to ground a minimum of six amps/ sources but will take up to 12. In addition it has a dedicated connection for a mains earth lead which is a definite bonus.As for earth cables systems can vary but the Apollos rarely disappoint and the Challengers are also good and less expensive. Atlantis are the top of the range but deservedly so.
The other application which has been a great success in mine and others' systems has been to ground the negative speakers terminals of my Vitus 025 SIA. You will see from the manuals section of the Entreq site how to do that and how you need two separate Minimus boxes or a bigger box with two self contained grounding boxes. The Poseidon is the best choice and the more expensive option but two Minimus boxes will do the job as will the new Tellus II ground box. The latter would leave you with only one spare grounding post and Minimus boxes are really only adequate for one unit.
So far as I am aware there are no issues with panel speakers for that application but I haven't heard of it being used for such speakers so it would be sensible to check first. If there were a problem I think I would have heard by now.
Entreq are very good at letting you try their products before you buy so their dealer(s) in Portugal should be able to help, but if that option is not open to you I am sure Entreq would be able to help or to point you to their nearest dealer. If you decided not to buy they will expect you to meet the cost of returning the items.
So question 1 for you is how many items do I want to ground and with which ground box(es) and with which earth cables.
I'm conscious I started this reply with the expensive options which I think are the best value but the less expensive options are very effective and if you do try them I don't think you will be disappointed.
I hope that is clearer and do come back to me if it is still not clear and I'll do my best to resolve any outstanding queries
I think I understand now. You are not using the Olympus for grounding both negative SIA-025 speaker terminals because it would cause a short? You must have two separate grounding boxes?
Regards
Cyclopse
Yes Cyclopse I use my Poseidon for the negative speaker/amp grounding and for the amp grounding through an input on the amp.
The two Siver Tellus and Olympus ground boxes are used to ground my sources, some Entreq interconnects and speaker cables and the dedicated post on the Olympus to an unused mains outlet
If i have not grounded the amps, nor the speakers, nor the sub (where there is apparently a lot of emi apparently)...where would you suggest i start on these 3?
Hi Lloyd.
I would start with the preamp and power amp. I only use my sub for AV purposes so not sure where that would come into the appropriate priorities for your system particularly as I seem to recall that grounding your Wilsons is a big job, and how grounding the sub would work in the absence of grounding the main speakers would need to be investigated.
Aside from that my next priority would be the Zanden front end using a separate ground box from any analogue components. As I think you are aware Entreq advise against mixing any earth cables to digital and analogue components on the same binding post of a ground box.
