Entreq Tellus grounding
Bridging that speaker terminal to an external system star point via low impedance path could improve s/n, if such benefit were obtainable that way.:confused:
Never, ever connect amplifier speaker terminals to anything other than a loudspeaker or sub-woofer system.
Doing otherwise could let all the smoke out of the amplifier.
Cheryl,
in that link did you find any mention to 0V Reference/signal ground or RCA phono interconnect type cables (only reference I saw was comment about cable shielding was 'no connection to earth (or even circuit
common) is needed for shielding to be effective
' that is not completely applicable in terms of scope and focus-requirements), isolating signal ground from power supply, stray field transformer EMI situation?
Thanks
Orb
On of Jim Brown's pet peeves is incorrectly mounted RCA chassis connectors. He writes about them in many of his 50 papers.
Some 20 years ago, Neil Muncy wrote the seminal paper on signal grounding and shielding.
Speedskater, are you adamant on this? Even though Entreq is a passive device, and not powered? I'd hate to deal w/the fallout of getting this wrong (suspect Entreq wouldn't buy me a new power amp in the consequence of said risk).
Cheryl,
Regarding speakers, I do not know if Tannoy is the only one but they provide an earth terminal, subjectively those that have used it seems to suggest that it can help sound quality but yeah that is subjective.
Thanks
Orb
Section entitled 'Loaded Words That Cause Misunderstandings' discusses the concept of shield, earth, signal grounds and the ground plane under an antenna etc. This is all very basic stuff but unfortunately for the non-engineer type the concepts are probably foreign and only marginally comprehensible without some in-depth discussion of electronics if not physics.
Section entitled 'The Pin 1 Problem' indicates potential problem when cable shield is connected to a signal ground out of convenience, ignorance, or some other aspect not generally conducive to signal integrity instead of to the case. No distinction is made between balanced or unbalanced although the problem was originally named after the XL(R?) pin 1 terminal.
I suppose grounding the input terminals might have some benefit if it addresses the 'pin 1 problem' by adding a solid connection to the case, but that would involve actually tying the connector right to the case where it penetrates, not tying it to a box somewhere outside of the case. That makes no sense in the context of this article nor does it make any sense to me based on what I know.
Unfortunately, in some cases even case grounding is not such a simple thing. I have worked on amplifier where moving the terminal strip with the power supply case ground connection on it just a few inches from where the manufacturer attached it originally completely messes up the s/n so apparently it had to be tuned by the designer to optimize its effectiveness.
This was low-power Fender tube amplifier (12" speaker) with all the wiring inside a metal chassis and all the larger components mounted above the chassis with connectors penetrating the chassis.
I never did figure out why the case ground connection was so sensitive to location. This was before my course of studies and such amplifiers are no longer available for me to investigate further since I no longer really play or have access to such amps needing repair. One of them had a broken case connection and when I re-attached it with a jumper cable I quickly discovered just how sensitive that connection was. I tried soldering it with a short lead and moving it around because it never really did quiet things down completely no matter where it was placed. It had to be replaced exactly as originally built or the amplifier hummed quite audibly. When replaced at its original location there was only a quiet buzz.
I also worked on amplifiers where the case ground connection is tied in at the corners of every PCB on the mounting screws. These were solid state. As far as I can tell, every single one of them has the so-called 'pin 1 problem' because the RCA jacks are universally mounted to either bakelite (older equipment) or plastic (newer equipment) and the ground connection ties directly to the circuit board, not the case.
Nearly all of these amplifiers are in wooden or plastic cases too so there is no shield to connect to anyway except maybe (not necessarily) the metal chassis (if it has one) that does not really shield anything at all when it consists of only an open frame and/or most of the components if not all of them exist on the outside surface of the PCB, above any potential power and ground planes (if the PCB even has such - many power amps have only top and bottom layers with almost no shielding in the PCB at all).
Any shielding in such amplifiers is localized to the area that requires it and the rest is designed out for cost reasons. There really is no global 'case' to connect the RCA shield to anyway and it boggles me why hanging a long heavy wire off the unused input connectors does anything except add more antennas to a system that already has a marginal capacity to reject noise anyway.
In such amplifiers it makes no sense to run the RCA shield terminal back to the internal star connection either since the PCB trace or ground plane is usually heavy and short enough to take it straight to the chassis via PCB corner screws.
My Onkyo receivers all have metal case that is sort-of a shield, but not completely since it has lots of penetrations for air holes and plasma display panel. I am not sure if my Onkyos isolate the RCA jack at the case penetration. I only removed the HDMI to repair the failed local regulator capacitors (Onkyo HDMI is known for this problem) and ignored everything else.
If the RCA are screwed to the case it cannot be individually like the way the HDMI are done. It would have to be from a common connection or two because there are simply too many of them to put a screw through each one.
For some televisions the chassis is hot and must be kept isolated from the RCA shields. In that case there is some other technique employed that I am not aware of to float the signal ground from the chassis and all the controls are either insulated push buttons or for older equipment plastic shafts on all the controls with the metal mounting nut and chassis concealed behind the plastic case to ensure no one gets killed even if a knob falls off.
Regarding whether or not it is safe to connect speaker terminals to a ground bus, that depends on if the amplifier makes a hard connection from the terminal to the case/power/signal ground star connection internally or not. For some amplifiers, both the output terminals on a channel are driven and it might not be a good idea in that case.:eek:
For some amplifiers, there may be signal transmitted or received on the negative speaker output terminal (even though it routes back directly to the case/power/signal connection) just because of the impedance of that connecting path and the current flowing through it. Transmitters might be the speaker itself that is sinking current back through that negative terminal or some other component like a transistor in the amplifier that could either be sourcing current into that path and/or using it as a reference in which case it is a receiver. In either case I cannot see any benefit to routing a ground connection between speaker terminal and line input shield so I assume this is not being done or it could cause problems even if it passes through an external box on the way. Replies on the thread indicate that separate boxes are used for line level vs power output and in my frame of reference that only makes sense because to do otherwise might be playing with fire.
Similar considerations apply to input stages. Tying unused inputs to a thick external ground wire has the potential to inject some sort of noise into the signal ground because of that 'pin 1 problem' and the more connections there are to that external box the lower the impedance of the injection path while the longer the connecting wires are and/or the more of them there are, the larger the potential antenna doing the injecting.
At least they are all going to be referenced to some common node, hopefully? In that case the risks are less than the risks that arise from connecting even more components/antennas to those inputs that could inject even more noise, but I do not see how grounding those connectors to an external box does anything to improve the s/n especially if they connect to DC isolated metal plates in some container.
Ideally they want to be referenced directly to their own internal signal ground or at least to local case ground if there is current coming in on those shields that could upset the signal ground. It almost seems as if the whole point of using isolated plates inside a grounding box (if that is what is happening) is to avoid connecting to anything at all.
It seems to me that the entire box is just cosmetic or at best a high frequency capacitive coupling scheme though the capacitance will be small even with very large plates if the dielectric between them is thick and then how do you decide what order to attach your components to the stack of plates? Who lives on top, who is on the bottom, who is in the middle, and does it make a difference or not? If it really does anything at all there must be some interleaving of the plates for symmetry or the order of connection might change the performance.
I just do not get the concept based on the info available. In any case, such grounding decisions need to be made intelligently and with deliberation if not measurements.
Sometimes it is not clear why one scenario works and another does not. I am no physicist and even modeling microstrip or stripline in a simulator is taken care of for me by the big guns who designed the simulator. Add dimensions and push the 'run' button. Even 3D field simulators are similarly designed to be more user-friendly in terms of model assembly and not so much explaining how it derives the resulting response. For that, a solid technical education with specialization is required and that probably involves equivalent to Ph.D in physics as well as solid mathematical programming skills and maybe a team working on the product through its entire design cycle.
Modeling an entire metal case with all the penetrations and such is basically impossible with a complex shape. Like analog simulation of thousands of transistors, field simulations of highly complex shapes become unworkable both from convergence issues and computational intensity let alone the inaccuracies of the model. It gets difficult very quickly and the only way around that is to break the problem down into pieces that the simulator can handle efficiently and accurately while plugging in rough approximations for things like current sources or entire signal blocks (in the case of analog simulations anyway that I have direct experience with).
I just cannot imagine anyone designing a grounding system that attaches outside of the cases of individual components that can actually have a beneficial impact unless it is customized to the system if not part of its initial specification. I have never encountered any such animal before in my entire existence.
Maybe someone figured out a way to do it. I am willing to be convinced. I am not going to trust even my own ears for it though unless I can see a marked change in measured performance or hear an incontrovertibly dramatic or at least detectable difference via DBT and even in that case I still want measurements to tell me what I heard to prove it was actually beneficial and not degradation. Given the range of system topology that is possible with arbitrary specification of all the components making up the system, it seems that even if there is potential benefit, that benefit is goingto be so highly system dependent that results would be all over the place.
As I was indicating, the actual grounding decision/device that makes the improvement might be any one of many things and just tossing a bunch of modifications and additions at a system with some rote approach seems to me likely to fail objective evaluation based on my experience. This is why I keep asking about instructions for installation. I want to know if the specific details vary based on components and topology, or if it just consists of a bunch of boxes with a single recipe for connecting them all up.
Yeah I get the misunderstanding section and how many may confuse the three "grounds" that are required in the audio components; makes sense to include it.
Heh I skipped Pin 1 problem section as I thought it was just covering the way it is wrongly used for XLR, I now see he expands upon that, including his Fig2 diagram doh :) - but still too simplistic and needed further technical expansion on single ended topology-signal input IMO.
My thoughts are that the paper does not seem mention or consider isolating-"separator" (or reducing noise) the signal ground from power supply (ok in theory if done the design ideally it should not be needed), or the potential use of feedback divider ground/RF filter ground (lowpass), both can be pretty important for hifi gear and furthermore if done incorrectly (quite possible with constraints on audio designs in terms of topology/budget/size/manufacturing logistics/etc) can cause more noise rather than reduce it *shrug*.
I guess he is more interested in the ideal-perfect way of doing this, although I do feel it is much more complex than that when looking to have an A-weighted S/N much better than 90dB (more important these days).
Cheers
Orb
Adamant about what, exactly?
Connecting amplifier output terminals, to non-speaker things?
Look at it this way:
If the amp design has the terminal connect directly to the chassis, then no problem, but it's not the output that is concerned about noise, leakage and interference.
If the amp design has the terminal referenced to ground, then it maybe OK, but you just added an interference antenna and a ground loop. And it may make the amp unstable.
If the amp design has the terminal not at ground potential, then the smoke comes out!
So there is nothing to be gained by making the connection.
It's the signal inputs that are concerned with the:
STGP :: Signal Transport Ground Plane
ZSRG :: Zero Signal Reference Grid
ZSRP :: Zero Signal Reference Plane
Conductive Structure
To reduce the possibility of interference antenna pickup, speaker cables should be twisted (and symmetrical). So just adding a wire to one terminal will make a good interference antenna, just ask Jim Brown.
I guess part of that is also not having it insulated correctly, along with its termination.
do you know if he covers in detail common impedance coupling/common mode voltage with regards to unbalanced (using RCA) multiple interconnected components?
This would be further compounded by mix of Class 1 and 2 devices.
Thanks
Orb
Cheryl, I don't know what to say. I pretty much tried Entreq on a whim. Tbh, I do believe I had no expectation of a positive effect at the time, in fact I was seriously anti in attitude to begin. I mean, like you, I thought what the Hell can a wooden box full of inert sand/minerals/chemicals/silver and copper plates do? Even worse, not connected to the mains, not in series w/the system, but in parallel, connected to in effect redundant input output jacks. yep, this really was going to be a waste of my valuable time. But i had achieved such brilliant results going to 8kVA balanced power, and I thought maybe addressing power/electrics in a different but related field MIGHT prove fruitful.
I truly send more back more stuff than I buy. So many tube amps, cables, cartridges, isolation supports, loudspeakers do absolutely nothing for me, in fact most are deleterious to good sound imho. I say that to avoid the label of being a sap that one member continually makes.
There was ZERO hard sell, indeed the UK distributor deliberately made no comment until I made mine, not wanting to skew the trial. Even then he didn't add to my comments, kept conversation very low key. But as a Eureka moment took hold, of course we talked enthusiastically about WHAT THE HELL JUST HAPPENED?!
So there you go, my entry into grounding. And it's effects still show, often thru it's absence when occasional disconnecting is needed.
Btw, I'm an objective/subjective fence sitter/resident of the middle of the road. My work and it's effects as an osteopath cannot be measured in any conventional way, yet most of my patients and I am convinced by the efficacy of my work. Yet I have no time for religion, you cannot convince me of the Divine no matter how hard you try.
Where does your objectivism end and subjectivism start?
Well if we want to take the plunge into philosophy all I can say is that for me the divine begins where my understanding ends because everything beyond that boundary is mystery.
Science seems to be the one 'religion' that best explains the mind of God to me, if such even exists. Try violating God's law in the Bible. Wear clothing of more than one fiber (any blend will do). Now try violating God's laws in any physics textbook. Flap your arms and fly.
I think the irony is self-apparent. The science that religious people often decry is the same thing they crave: a working explanation of why things are and a set of rules to abide.
I would rather not sit in my living room imagining I am flying when in reality I am just flapping my arms like an idiot. That makes me feel foolish like I completely missed the spiritual point that latter-day saints like Heisenberg and Einstein made. Until I have objective proof, I cannot help but worry that I am being foolish.
Like every other duality, subjectivity and objectivity form a continuum and we all fall somewhere toward the middle by default because no one lives at infinity. Every one of us is a fence-sitter like you.
I consciously tilt my scales toward objectivity to avoid foolish mistakes. That is all. Objectivity is a strategy, and like all strategies it can fail. It is not a place one dwells, not a cloak one wears, and not a panacea that all wisdom revolves around. It is just a tool.
If a person has the money to invest in audio placebo treatment and gets perceived benefit from it, that is a great thing. I fully support such investment for those who can afford it. I even support it for those who eventually decide they were deluded because then at least they learned a valuable lesson. The higher the price the more impact of the lesson.
Since entertainment is only a small and largely optional part of my existence I prefer to confine my expenditures on it within the bounds of reason rather than leaping to decisions on the basis of emotion. These grounding schemes represent substantial investment to someone in my circumstances.
I am open to persuasion with evidence. As any attorney knows, eyewitness testimony is one of the least reliable sources of evidence. Humans are too complicated to use as measurement device unless placed within a context where the only information they operate with is specifically limited to the question being asked.
I know that physicians have tough decisions to make and honestly I do not envy you that power over life and death. I know that despite all your scientific training you revert to subjectivity on a daily basis out of expediency as well as necessity. We all do it.
I just prefer not to do so when such high price is at stake and there is no necessity whatsoever. Expediency has its place but tens of thousands of dollars in expenditures is not it, not for me anyway.
Likely true in most cases but as I have repeatedly indicated, it may still help address problems in some circumstances.
I just am not seeing any such circumstances in the average audio amplifier that exists within larger audio system. So basically I am in agreement with you and that is why I am still puzzled by these devices.
Take k-ohms measurement between the grounding terminal you want to add to your speaker terminal and every other terminal on the box you want to use for grounding. If it has no DC connection (open circuit) it may be safe to connect it to your speaker terminal.
Take similar measurement at your amp (disconnect the power and speaker first) to the amp's case/ground using ohms or continuity measurement. If it measures 0 ohms it may be safe to connect it to a grounding box.
Either one of these conditions may prevent shorting high current path and damaging something. If neither condition is met then it is probably not such a great idea.
No guarantees. As indicated, just hanging a big antenna off a speaker terminal could induce noise or even instability, especially if the amp already has stability issues all on its own. Also there is no guarantee that the negative speaker terminal connection will not change when a relay is energized.
Another investigation is to write to the manufacturer of your amp and ask tech support about their recommendation regarding such grounding device hanging off a speaker terminal. My guess is that you will get no encouragement for such thing since they did not design the equipment to be used that way.
As far as any liability goes, if you purchase a device and use it according to the instructions and it incontrovertibly turns out to be foolish and damaging thing to do, then the seller bears full legal responsibility in a just world IMO. YMMV.
Kind of late to the party here, but curious if anyone has tried signal grounding with an ARC preamp and had positive results? :confused:
Just completed all 8 of my components being grounded. Started grounding 2 yrs ago w/preamp, then onto phono and cdp. Then to power amps, and now my Zu sub amps ever since I last wk installed the upgraded Lundahl transformer Hypex's which I ordered w/custom ground posts. I'm pretty much at the limit of my S. Tellus, w/8 spades shared over 4 ground posts on the S. tellus.
Another layer of noise removed, another window opened, another step twds a clearer view of the music. Grounding just continues to give.
Completed what Barry has just been trying, the power amp spkr -ve terminals grounded to separate Silver Minimus'. A really sweet impvt, enhancing a little natural warmth in the system, really rounding out notes nicely. Not sure at all what this is doing differently from standard grounding, but whatever, it's most welcome.
Considering a final nuclear option on grounding, an Olympus Tellus alongside my Silver Tellus. This will provide me w/10 ground pegs to share btwn 8 components (8 Apollo spades/16 Atlantis spades), and unique ability amongst Entreq grounding boxes to ground via the central peg direct to the one of my dedicated lines via my Silver Cleanus, hence grounding the mains for the first time.
One for the future.
One for the future.
Glad to hear that it has worked for your system too Marc.
Now that it has been up and running in mine for a week I really am in no doubt about its benefits.
Well, we're going to do reciprocal visits, will be interesting to hear how progressive grounding has evolved our system capabilities, incl this latest one.
Thanks Paolo.
I'll try and do that later today, but simply you just fit the earth cable's spades to the negative amplifier speaker terminals, and then put the speaker cable spades on. Earth cable side on and speaker cable bottom on and earth cable spade to Silver Minimus.
Best wishes,
Barry
Hi all,
I am after some advise from the Entreq experts on this forum (of which there appear to be many). Firstly, I just want to get out of the way that I have an extremely basic system - not even in the same galaxy as the systems here - so I was rather hesitant to even list it. Nevertheless, after you've checked out my gear and had a hearty laugh, perhaps you are still willing to share some wisdom nonetheless. I should further add that despite my extremely inexpensive gear, I believe I have very good listening skills. I can hear very easily indeed, for example, differences between interconnects and power cables, etc.
Anyway, a week or so ago I decided that given I am actually in essence happy with my gear it was time to try this Entreq gear, since it is reasonably priced (and fits within my philosophy of no more than $1,500 per component) and I am well aware of the benefits of grounding and low noise floors in general, since I do audio editing on a workstation and these things are very important in that environment.
Having spent three days reading this entire thread, I came to the conclusion that although the grounding cable is more important than people might give it credit for, most people felt the "entry level" for Entreq to be the boxes in the silver series (i.e Minimus Silver and the larger / more advanced versions thereof). Alas, after placing an order with my dealer for a basic Minimum Silver and entry level RCA Copper cable, I found he was out of stock of them. Not wanting to leave me empty handed, the dealer kindly lent me a plain copper Minimus box and - to my surprise - a Konstantine RCA grounding cable.
Now I did not even realise I had the Konstantine cable when I connected the Entreq box up to the spare RCA input on my Musical Fidelity M1 amp but started to wonder when the sound did not "warm up" as I thought it might but instead became more detailed, more focussed and more forensic. And I was also surprised at how the sound changed as soon as the box was connected (there was no "waiting period" as others reported - the change was dramatic and instant and did not change at all even after 3 hours). But I digress.
The question I am now facing is whether this plain copper Minimus box plus Konstantine cable is a better bet than my original order of the Minimus Silver and the entry level copper cable? I've only really read of one review where the reviewer went through all the boxes. They described the difference between a plain copper box and a silver box to be rather dramatic, yet as one observer pointed out, this person already had a great system to begin with and suddenly it was all becoming inadequate when going down from the silver box to the plain box yet previously they had no boxes at all and had no complaints!
The other thing I now need to consider is that these Entreq devices also seem to work on my audio workstation - just connecting the box to a spare RCA out on the main soundcard has produced exactly the same result as connecting it to my Musical Fidelity amplifier. So I can now also consider using the budget to get two plain copper boxes with Konstantine cables versus one box only (silver) since the two copper boxes are only about $110 more than one silver box.
So I guess the question is has anyone here listened to a plain copper Entreq grounding box and then compared that to the equivalent silver version, when using the same grounding cable (preferably Konstantine). If so, what were your impressions when making the switch to the silver box? Was it less or more dramatic than changing the type of grounding cable, for instance?
My impressions with the copper box and Konstantine cable for better or worse thus far are:
1.Not really as noticeable a "blackness" as I was expecting (especially in light of what others report).
2. Less grain
3. More texture detail in the midrange
4. More focussed highs
5. Sound feels a little recessed in the "air" region compared to no Entreq at all.
6. Less Euphonic sounding but in a good way, not a bad way.
But what I feel I don't quite have is that sense of effortless pace and timing that others say they get with the Entreq stuff. Of course we are talking about a really budget system here so I suppose miracles cannot happen. But as the budget is somewhat constrained, I'd still like to get the best out of it as I can (for both my workstation and the gear in my profile) without going all silly about it.
Thanks
Hi there and welcome to the club.
My first experience was with one base Minimus and I think a copper or silver earth cable connected to the CD and the improvement in the sound quality was instantly apparent. Since then I have made a substantial investment in both Entreq grounding and their i/cs, speaker cables and power cables and have been delighted with the successive buys.
The Entreq grounding has the big advantage that you can upgrade incrementally as resources permit and extend it to all the components in your system as resources permit, but if you can spend rather more to begin with it is more cost effective than 3 or 4 less costly initial steps and not so many boxes. I started with the base Tellus and the copper and silver earth cables which were very good but in retrospect I should have started with the Silver Tellus and the silver earth cables. The performance of the Silver Tellus was a significant improvement and enabled me to earth the other components to great effect.The Minimus is good but will only earth one component whereas the Silver Tellus will serve 5 or more components.
If that is not possible to begin with then start with the amp as you have done with two copper Minimus and Konstantin earth cable and add further Minmus and silver cables as resources permit but if you could stretch to a Silver Tellus to start with and silver or copper earth cables it would in my experience be something you would not regret and you can move up from there.
The benefits are cumulative so the more components you can ground the better the sound will be in the ways you have noted. The noise floor should be dramatically reduced and the whole sound becomes so much more musical and natural.
Also talk to your dealer to see what sort of deal he will offer if you want to trade in initial purchases for subsequent upgrades. If he is supportive of trade in upgrades that makes life a lot easier.
Hope that is helpful but don't hesitate to come back to me if anything is not clear.
