That is one of the aspects I need to discuss with Jorn of Tidal when he visits me at the end of this month, Wisnon. But as we both know, it is not only a matter of lacking bass or getting more bass but also laying the foundation of an audio system and the space it is capable to create. A solid bass foundation is imho crucial for the realism and space of an audio system.
absolute bass headroom power and extension corrupts absolutely.
I would echo Audiocrack's comments on the added bass towers. this is not a matter of just adding subwoofer capacity. if you add 'headroom' to your bass capability that is truly seamless, and I mean designed in by the speaker designer to sound 100% coherent, then everything you play has this ease and weight that has it's effect up and down the frequency range. the bass towers of my MM7's extend to -3db at 7hz and -6db at 3hz......and only crossover at 37hz the way I have them set up. but they improve the mids and highs too. overtones from any frequency get filled in in the lowest octaves. and lots of headroom gives you more linearity in the audible frequencies. the -4- 7 foot tall 750 pound towers and walls of the room disappear and decays are endless.
recently when I did my ceiling project (closed up the last of the ceiling bass trap) and then had to adjust the bass towers to blend with the new flatter room, it was very interesting how tiny adjustments in each of the 4 parameters of the 4 individual amplifiers in bass towers had such an effect everywhere up and down the frequency range. it made a significant difference between moving the adjustment what seemed one hz on the crossover, a tiny bit on the 'Q' adjustment, a tiny bit on the 'bass volume' and the 'bass extension'. that was not logical that these very tiny changes to towers only crossing over in the mid-30hz range should be so evident. but it was.
it did not make sense to my mind, but it definitely made sense to my ears. real life bass foundation is not a trivial issue. and the last step in going from 'good enough' to 'over-the-top' takes you to another place.
and I can relate to the whole wife-budget issue too........with my Trinity dac and CAPS v4 Pipeline I've used all my 'good boy' points up for awhile.
