OK, so a $35 PCB and a $30 Crystek = $485 how?
In any case, we BOTH know the clog is only controlling the Power supply, which is where the REAL magic is. Come up with a killer recc for the clock power supply, will ya?
PM me your tel number and we can more efficiently thrash this out one day…should be a fun call.
That reclocker is more than a clock on a board. The Crystek was just an example of a popular low phase noise clock. That reclocker can be fitted with a variety of clocks depending on budget.
$35 get's you a raw PCB with no components soldered on:
Look at the X1 and X2 clock pads. They can accommodate any size of clock footprint.
The clock is only controlling the power supply? Are you completely out to lunch?
Acko's reclocker has a very low noise LDO to power the clock on the reclocker board.
HiRes, Bit-Perfect 32bits I2S - 44.1k, 48k, 88.2k, 96k, 176.4k, 192k, 352.8k and 384k
-DSD 64,128,256 and 512
-Based on Amanero and AKL-S03 Digital Isolator/Re-Clocker
-Dual Ultra-low Phase Noise Synchronous Audio Clocks
-Buffered Outputs on micro coax (u.fl) headers
-Direct connection to most DACs
-Drives ESS DACs in 'Turbo' Sync mode for the highest performance.
-All separate ultra-low noise (1uV rms) power supply and filters on board with very high PSSR
-Ultra pure 3.3V supply (<0.5uV rms noise) for Oscillator section. Options for external supply from batteries, etc
-I2C Port for reading sample rates directly from transport
-Led sample rate indicators on-board.
-Wide input supply 5-12V d.c. Regulated or unregulated
-Gold plated 2oz Rogers 4003 board
-Selection of finest components
-Assembled and tested
If you buy the turnkey version with the Amanero already attached for $485 it's the easiest way. Then all you need to do is snip the wires off of the amanero, and remove the Amanero from the GG. Mount the reclocker/Amanero board in it's place. Replace the wires that connect from the GG DAC board to the Amanero with wires that have U.FL connectors crimped on 1 end already. Or simply crimp or solder the U.FL connectors on the existing wires (not hard).
I'm sure Acko can provide them. Then plug them into the outputs on the reclocker, and connect the power wires to the reclocker DC input. That's all there is to it.
You can clearly see in the picture it will fit perfectly.
View attachment 23612View attachment 23613View attachment 23614View attachment 23615
