Many times. It's the amp. The microphonics as I call it, or hyper sensitivity always stays with the amp. I had to damp the chassis to some degree to shut it down. If you lightly tap the input or driver tube, it's a loud clank out through the speakers. This is with 1 amp only. The other amp does not do this. And I have swapped the tubes. Many times. It's never deviates from the one amp. The manufacturer thinks it's a bad solder joint. I think it's a persistent problem that was always there and was never resolved because the tech that worked on them only altered one amp to be up to current design. It's a clearly different circuit design between the 2 amps.
That could be it.
Per my post in the SET thread. After repositioning my speakers, My kT88PP Blade amp is so much better than my SET 845, I will be ignoring the 845 for a while. I am shocked how good the Blade is at bass. And everything else. Blade is a transformer coupled, differential design PP with a Mercury rectifier. As well as tube voltage regulation, tube driver and a pair of KT88 power tubes. Mostly Monolith iron. 78 lbs per 40 watt monoblocks.
