Spice is only as good as your models... At least that's what nearly 30 years of using it has taught me.
Capacitors, could be another techie article...
Exactly. I get the impression this is where a lot of people go astray, sticking "perfect" components everywhere. The best one, of course, is that just about every circuit is run off "perfect" power supplies, zero impedance at all frequencies ...Spice is only as good as your models... At least that's what nearly 30 years of using it has taught me
Class A means all the current, all the time, so "less demanding" is a matter of definition. What is different about Class D is the amount of HF energy they require, all the time, and the fact that the power supply rails can directly modulate the output signal, something not true in Class A or AB amps (within reason, the reason being the PSRR of the amp).
For cap models, most manufacturers provide static ESR and self-resonance; some provide shunt conductance as well. You can use those to derive a simple RLC(G) model of the caps:
Series R = ESR
Shunt R = 1/G
C = nominal C value
L = series L to create the self-resonance point for the series LC
HTH - Don
Sorry, Max, I don't quite follow you here. I have used LTspice to simulate a realistic transformer, this has helped me a great deal in truly understanding what's going on in power supplies. Using a voltage source will give you straightforward results, but it won't tell you what's really going on under the hood.Hi Folks,
I am (more or less steck with simulating my transformer in LTspice.. although I read up quite a bit about is it, it seems to be a recurrent problem.
Should I bother trying to sim it or rather take a voltage source a some suggest ?
Any hints appreciated.
Best regards,
Max
