reworked record and repro amps as well as new audio psu/stabilizer cardI don't know what modifications they perform, but that is certainly the right Studer model to pick.
Would it be possible to share the information on their rework?
In theory when dubbing tapes we should never play and record using the same model of tape machine - all the intrinsic mechanical issues due to the design of the machine are doubled. Perfection is using an ATR and a Studer for dubbing.I had an "all outed" The Tape Project Otari 5050mkII and now I have 2 MTSL A80RC for this very reason....
the chassis and the mechanics of the A80 or some other studio machines, should not be underestimated
Only by semi-local guys Jeff from J Corder and Eric at Gig Harbor Audio speaking of ATR and RMBI.Do you have any references on this interesting subject?
I spoke with John French at JRF Magnetics who experimented with the Bottlehead kit on the Otari and he advised the same - better to leave the machine as it was originally designed.Gene also said do not put the bottle head rollers on the Otari. The friction over the tensioners is calibrated into the motors. If you remove that friction, the motors are not able to control the tape speed properly. I have never heard of anyone who can reprogram the software or whatever handles that whole functional change.
How about another way. If you had a studor and an Otari. Which would you record onto. I bet you would say send from the Otari and record on the Studer. But I really don't know. Someone may correct me and say I have it the wrong way.
My Studer A80 RCMKII 1/2”, 2 tracks, 15/30ips is calibrated to 510nWb/m. I use ATR Mastertape with great results.Do you have any references on this interesting subject?
HI Christenen,had an interesting long night discussion session with Charles King @ ETF in Belleme last year and we discussed the possibility of skipping the decoding and the coding processes when dubbing tape....don´t quite remember what we ended up with, but he liked the Aquavit we brought with us...
Interesting thread, including your response - thanks!Interesting post.
Please realize that ANY deck can have a different "sound" when used for recoding versus just playing back a tape. U47 and I found out long ago that decks, specifically Revox, can make a better sounding recording than they do when just playing back that or anther pre-recprded tape. We've (and I have to add most of you reading this) have found how "wanting" the playback electronics are in most decks, hence the flourishing of purpose-built, "outboard" electronics. Not many folks have delved into outboard record electronics.
Please understand that the decks we are talking bout here have TOTALLY separate record and playback circuitry - AND different heads. Gain structure in the amplification is different and you are "de-equalizing" when playing back versus equalizing/de-equalizing when recording/playback - using different techniques/components in those networks. PB and record heads are different - different physical configurations and low impedance for record and (usually) a good deal higher for playback. And there is the necessity to ad bias to the record head to linearize the whole process.
I've tried upgrading the audio parts in a few 1500's can say that they don't come close to a even a stock Studer. Part of the problem has to do with the heads. Panasonic made most of the heads for all of the Japanese recorders - confirmed by John French. I've done listening comparisons between the Technics/Nortronics/Studer/Nagra/Flux Magnetics heads and the best description of what I heard was a "loss of information" with the Panasonics - for a whole number of possible reasons like core material/lamination thickness/annealing/wire.
Charles
From a tape duplication perspective, I mentioned a long while back that a prerecorded tape is also ALREADY equalized per some "standard" curve - be it NAB/IEC/AES. When you Dupe a tape you use two decks, the playback decks' electronics amplify and RE-EQUALIZE it back to "flat". The second deck then amplifies and EQUALIZES it back to where it was or to fit another curve. Think of all the EXTRA amplification re/equalizing components involved to do this. What about the amplitude/frequency dependent phase leads/lags that this additional "futzing" adds the original "sound"? You are also throwing away gain while adding noise to the process. Why not just amplify the tape FLAT and feed it to the record head where the bias is added? I tried this on a modified 1500 with a Nortronics Record head and drove it with one of my preamps sans the playback EQ (but with a little EQ for the record head itself). It sounded really nice. If I were into trying to provide the ABSOLUTE BEST best tape duplication services, I'd use an approach like this - otherwise you are COLORING THE SOUND OF THE MASTER TAPES tape(s).
HI Christenen,
Dueling replies - at the same time
Hope you are well and hope to see you next year!!!!!
I have my decks wired directly in/out if I want to use external hardware. I'm sure you've heard of a few outboard record units.So Bruce,
How do you dupe "without"? Do you have a way to turn off any equalization on both your playback and record decks? I wasn't aware that decks could do that.
A tape deck with good heads and upgraded correctly should have no difference from source to tape at 7.5 IPS and above.
As with LP's. I don't get cutting an LP from a digital source.... Blasphemy!!!Using a reel to reel to copy a cd is not a good use of that format. I personally think recording digital sources to RTR is an illogical decision. Digital should stay digital.
A properly working tape machine will make a certain amount of 3rd harmonic as its primary distortion component before the tape saturates. The 3rd harmonic, like the 2nd, adds richness. But if you are pushing the level so the meters are in the red, other harmonics will show up too (prior to saturation) making the tape recording seem 'louder' since those harmonics are used by the ear/brain system to sense sound pressure- their presence make the recording sound louder, just like they do in an SET.If this is truely what happens every time you dub a tape, how many levels would you have to go before the whole of the recorded media were not a compounded pile of mush and totally inaccurate to what was originally captured. If that is what tape does, I can see why no studio would want to use it.
The trick here is to not demand more than about 20dB of gain out of the opamp. If that simple rule is followed, even 5532s can be surprisingly neutral! You can get better opamps now and they are drop-in replacements with lower noise and much higher gain bandwidth product. But even so, you still don't want to break the 20dB rule even with modern opamps- the gain bandwidth product isn't high enough yet.Once the signal has passed through those 5532 opamps the damage is done.
