There is a new firmware update coming this week, so stay tuned.
Hi there, I am wondering if that new firmware will help with this?
My Ifi Zen stream rig sounds really good except there is an annoying issue which I cannot solve. Brand new unit.
Set up via wifi was successful.
Using Tidal Connect via IPad.
Issue: Upon playback of a Tidal master track there is a distinct regular crackle/squelch in the higher musical frequencies (somewhere around cymbal frequency) which seems to persist at same level even when volume is low. ie the crackle is not much affected by volume and seems to ride with the beat of the music. It is the kind of sound that you often hear when the battery on your audio device is getting low.
Have reasonably eliminated all external device issues i.e changed digital
coax cable, changed DAC/Amp (no battery this time) , changed headphone cable, changed headphones, still persists and wait…was given a replacement Zen Stream and same issue. So it points to the Zen Stream compatibility or settings.
It really does sound like a digital artifact that I am hearing, not a mechanical one or loose cable etc.
Q. When setting up in Ifi.local is there anything else I need to do apart from connect to the wifi? Is there some MQA setting I have missed?
Apart from the crackle the overall combination of the ZS and the micro IDSD is very good indeed.
Thanks in advance for your help.
