You say this like it is a bad thing.
That depends on intention and regrets.
I agree on the goal of cable neutrality. We are talking here about minor shading of resolution versus warmth. Both are world class cables. I think a 100% neutral cable doesn’t exist but we are closing in on it. I am envisioning a spectrum of sound from warm to detailed and neutral in the middle. For these two cables I am talking a smidge to the warm side of neutral and a smidge to detailed side of neutral.
Do you think a cable exists that is both a smidge to the warm side of neutral and a smidge to the detailed side of neutral? Or would you prefer neutral if you could identify and purchase it?
I find it interesting you don't need a pre amp for a digitally sourced high-end system, why is that do you think?No worries. Just roll in a tweeter at 12KHz or so.
I can tell you that a JBL driver converted to field coil sounds better than a stock JBL with the same diaphragm. I've heard the comparison. Worth the extra cost IMO.
I've been running them this way for over 20 years and since it sounds better, the disadvantage is apparently outweighed by the advantages. The field coil has reached a stable temperature in less than an hour.
I didn't say $3000, for the record. These days I'd start with a set of Audiokinesis subs to handle the bottom end; they are flat to 20 Hz and since there are 4 of them, standing waves are broken up so no need for room correction (90-95% of room problems are in the bass). I'd consider a refurbished Dynaco ST35, for the amp, perhaps with some upgrades. A set of Tangband full range drivers in a sealed box allowing them bandwidth to 50Hz or so can do nicely, supplemented by a Fostex tweeter or similar on top, both crossed over to prevent comb filtering. I'd use a Topping D90SE and perhaps a Shanling CD transport; no need for a preamp if digital is the only source. But if it isn't I'd get a Technics SL1200G, Hana cartridge and install an Oracle platter pad on the Technics. The stock Technics pad is terrible and if you've not heard the machine with a decent one, you've not heard it. There are plenty of preamps around that can handle a LOMC cartridge and drive the Dynaco ST35.
Inexpensive, nicely nuanced (musical) and can play a decent volume in most rooms no worries (the Tangbands are 96dB in the box with crossover), flat to 20Hz so can shake the walls.
The Dynaco (17 Watts/channel) can challenge any SET made no worries; you don't really find out why SETs went the way until you hear PP amps of similar power. The Topping DAC is extremely neutral (I have one and have compared it to master tapes). The weakness of the Tangbands is like any 'full range' driver in that the highs are beamy to a fault; easily fixed by a tweeter and a crossover for it. None of this stuff is expensive but it will cost more than $3000.00. I imagine if you were careful about things you could bring the cost down quite a lot.
This is the impression that I got from reading along during that period. I’m not sure how well served the system was from the way the Lamm boxes were arranged on the floor. I am also not sure what cables he had with the Lamm gear, but if it was Transparent audio cables, I would suggest that was not a good pairing. To hear what Lamm is capable of doing, you must have an appropriate speaker and you can not color the sound with the wrong supporting gear. Just my controversial opinion.
which neither objectively supports nor negates preferences. shades of grey at best. cases for ideal matches are simply data points, not proof or evidence. the ML3 is not 2 or 3 or 7 watts. it's 32 tube watts. the speakers are not 85db 2 ohm. they are on the reasonably efficient end of things. and no one is expecting miracles.Isn't that the case with every amp? Evaluating a speaker by itself, independent of a specific amplifier, or vice versa, is a fool's errand.
yes; mostly i'm not digging in. just hanging out.And here I thought you'd mellowed out since retirement.
how high end is it really? if adding a high level stand alone preamp sounds better, would it be added?I find it interesting you don't need a pre amp for a digitally sourced high-end system
so we continue to pump the narrative that Lamm gear can only be judged with certain speakers. yet we know other Lamm ML3 users using those speakers and being very happy.
why don't you bother Steve Williams with all this stuff? and explain to him how it's not working? he uses his own special cables. are they Lamm certified?yet myself and Francisco just did not prefer what we heard to alternatives. neither of us disliked the Lamm. we simply liked something else more for our own particular reasons.
maybe you two could issue validity badges for when gear gets sold and the reasons are legit so we can keep things properly approved.![]()
My favorite descriptor is "organic". Seems to be in vogue these days. Someone try to define that please. A synonym for natural? All of this just underscores the frailty of words when trying to describe sound in a "universal" context.
I think Steve ordered new speakers recently.so we continue to pump the narrative that Lamm gear can only be judged with certain speakers. yet we know other Lamm ML3 users using those speakers and being very happy.
I agree with this. Compensating for one piece of gear that is colored with another piece of gear that is colored or with colored cables, is not a very efficient approach to system building. Sometimes though, it is what one must do given the gear he has already chosen. And some people follow this approach that seems to work for them. It’s pretty hard to find neutral and natural sounding components, in part because it is difficult to assess the contribution of the rest of the system in which a component is placed.
I don’t honestly know on the “both a smidge” question. The upper end cables I have tried all seem to have strengths and weaknesses. I would prefer a neutral cable if one existed.
What’s your opinion on the matter?
Not sure but OCD Mike also advocates no pre amp with Playback Designs and Meitner DACs which most would put in the high-end category. Yet with analog sources a pre amp will make or break a system.how high end is it really? if adding a high level stand alone preamp sounds better, would it be added?
certainly there are degrees of high end. it's not one singular spot.
Peter,
Unfortunately you decide to comment on my intentions and acts in an other poster bullying comment . Why not asking me directly before writing speculative false information?
Lamm's are not neutral. As I owned the ML3, ML2.2 and M1.2 - in order to sell the ML3 I had to get a ML2.2 in part exchange ...- and during a short period I had all of them playing side by side, driven by the LL1. They sound very different. If you have doubts read what your friend Romy wrote about each of them.
advocating no preamp with a high level dac and going direct is different thing all together from the question of which performs better. did OCD Mike do a specific compare and detail his results? i'm asking the question as he very well might have. i do not follow him so have no idea.Not sure but OCD Mike also advocates no pre amp with Playback Designs and Meitner DACs which most would put in the high-end category. Yet with analog sources a pre amp will make or break a system.
Francisco, do you think your Wilson speakers were the best match with the Lamm amplifier?
What cables do you use between the preamp and amp and speakers?
Did you use a rack for your Lamm gear or did you play them on the floor as demonstrated in the photographs you shared?
You had eight boxes and I saw them all spread out on the floor. How much time was there between insertion into your system and your decision to sell them?
Finally, did you consult with David Karmeli about amplifier speaker matching and what did he recommend? Thank you very much.
+1objectively maybe there is a point of preamp performance below which the direct simplicity of eliminating the preamp and cables surpasses adding the preamp. and preamp performance above that point leans toward having one. this is both a dollar and performance question.
(...) objectively maybe there is a point of preamp performance below which the direct simplicity of eliminating the preamp and cables surpasses adding the preamp. and preamp performance above that point leans toward having one. this is both a dollar and performance question......and price/value is not linear. might even matter which brand of amps and preamps you use. (...)
