Hello Micro
LOL your kidding right. Not for the professionals!! Why do you think the professionals wasted their time on them?? For the DIY set?? When a manufacturer specs a custom woofer/midrange, aside from materials used, what parameters do you think he uses??
I'll give you hint T/S
What myth is that?? You do realize that a 3db pad means that with a 100 watt peak you are dropping 50 watts across the attenuation resistors. If it's a 6dB pad it's 75 watts. Now you question why designers use large power resistors in passive networks??
Granted that there is normally no attenuation with woofers, mid ranges on the other hand, can have a good bit between band pass attenuation and any notch filters used to smooth the response.
Any attenuation or notch filters used removes amp headroom and screws up the dynamic linerarity of the system. Typically you end up with full amp power for the woofer only. The mids and highs are at best runing at -3db or quite a bit more below that. The kicker is the transient response is in the upper frequencies so if you limit the power there the system will just become strained when pushed.
As far as box speaker being dinosaurs not hardly. They are not going anywhere. Panels/dipoles will always be in the minority. Bass reflex rules, the best compromise for efficiency, power handling, bass extension and size.
Rob![]()
Thanks Rob .. Often I wonder if microstrip is not pulling legs. You know just stirring the pot. microstrip is extremely knowledgeable about the technical side of Audio, but his agenda is clearly to "defend the audiophiles who cares about High End Audio" at all cost ...
This post about Engineers at Wilson not considering the Thiele Small parameters will give anyone pause but hey .. That's microstrip for you
emphasis is mineBTW, I am not sure that David Wilson chooses his drivers the way you refer - at less from what I could read during many years about the properties he wants his drivers to have. Assuming that "Thiele-Small parameters describe very well a driver" is nice for DIY building subwoofers, not for professional manufacturers. And yes, I have built speakers long ago this way, and even recently built a 60 litters box to measure the TS parameters of a 15" woofer - REW is of great help for these measurements.
