Well, first, I did say that I don't consider any single FRD Zu speaker before the Druid 6 as fully convincing on symphonic music. And even with the Druid 6, that would be suitable only in a fairly contained room. But I listen to symphonic music on Definition 4s which each have TWO 10" FRDs + a supertweeter + a 12" powered sub. The sub and the tweet are on low pass and high pass filters, respectively. The amp sees no crossover; the FRD is driven directly.
This is all very much affected by the room one is trying to pressurize for crescendo at orchestral scale. 47 years ago, I could put orchestral scale in a dorm room with a pair of Large Advents and a Marantz 240 power amp. But in the hifi store I worked in, which was in a large house with an open plan first floor, doing the same took Double Advents (we were doing it before Harry) and a Marantz 500, bridged Crown DC-300A used as monoblocks, or later an SAE 2500. At that efficiency, even an ARC Dual 150 wouldn't cut it. We did the same thing with Double Dahlquist DQ10. racked like the double Quad ESL system. I don't know anything about Mike's room, but he has...what...22 drivers in stereo in that system? Are you saying no speaker can do convincing symphonic music with fewer than 22 drivers? C'mon...there must be dial on that concept -- it can't be a switch.
The largest driven surface area we could set up in that store was via Magneplanar Tympani IIIa tri-amped with monoblocked Crown DC300As on the bass and ARC Dual 76As on mid and treble panels, using an ARC or Levinson electronic crossover. It didn't matter how loud you played it, the symphonic perspective was 2/3rds back in Boston's Symphony Hall, because the Tympanis had resolution but not shove. With the Double Advents, the sound was less resolved but more vivid. You got pulled up to a seat about 4/10ths back.
Back when I was still dependent on crossover speakers. I ran "doubles" a few times and found that doubling the driven surface areas yielded more than 2X benefits in scale and dynamism. Double Advents sounded disproportionately scaled over a single pair. Same with double LS3/5a (yes, I really did it, to great benefit). And in one of my large rooms in Massachusetts, I briefly ran doubled ProAc EBS -- in some ways a YG Hailey more traditionally constructed circa 1985. I point this out to say that Definition using two FRDs instead of one yields disproportionate gains in scale and dynamism over a single Zu FRD. And then there's the 12" sub taking on the foundational duties. Which has more driven surface area -- Zu Defs with 4 10.5" FRDS + 2 12" subs + two compression supertweeters, or YG Haileys? YG doesn't spec its drivers' sizes but it's easy to see, Definitions win on driven surface. There is the contention that a 10" FRD can't resolve upper frequencies but that's a theory based on old materials and build methods for the drivers. Zu is inspired by the past but not living in it.
The next Definition you will hear this spring, Ron, is now likely to show up sporting three Zu FRDs, each with its captive concentric supertweeter. The 12" sub continues. And you will hear Dominance 2, which including supertweeters will have 18 total drivers per stereo pair. How many Zu drivers are necessary for convincing symphonic presentation in a normal room?
If Sean stays on schedule, we'll see come Spring.
Phil
