One for sale in UK...are they multi-voltage.
Maybe Keith'll snap 'em up before I get those Apogees Lol.
The Jeff Rowland has input transformers, funny that the preamp was so problematic but the input transformers aren't.
Thanks for the update, Keith. It is nice to have a challenging project during this time of lockdowns and home confinement. Good luck in your continuing search. If someone does not point a gun to your head, will you keep looking for an amp, or are you focusing your efforts now on a preamp?
Good point. Weird indeed. We also checked that the MF carried ground throughout the input/output process and indeed it did. There is nothing anyone can figure out why the two pieces are incompatible, but yet we are here.
Symphonic line Kraft, used.
It's the inductive surge caused by the AC, if you can put it on the opposite phase that may solve your problem, if it's 240V it uses both phases and there may not be an easy solution, but given your investment already maybe a Taurus BPT with surge and emi filters would be possible, it may both solve the problem and be an improvement...
It happens even on my Torus AVR-15
(...) I can run the MSB direct to the amps with no issues, but stick the preamplifier in and can get a blown fuse when my air conditioner comes on. I've had multiple discussions with MSB and SST and they've never heard of anything like it in 15 years. (...)
Update: A Linear Tube Audio MicroZOTL preamplifier should arrive in a week. The last amp to try is going to be a Pass Labs X350.8. So hopefully by the end of the summer, I will have procured the best YG preamp/amp combination!
Why not something like XA160 monos? I think the Class A Pass amps have a higher potential for good sound...YMMV.
I wish YG would add more bass woofers to the Hailey and Sonja. Similar to the Magico A5 with its 3x 9". A single bass woofer I just think doesn't cut it. Even the sonja 1.3 with i believe dual 10s felt bass light.
