It sounds exaggerated because it is not under control and sounds indistinct or muddy. This is often because designers design a box with a high Q that gives a bump in the mid/upper bass but it doesn't stop and start quickly and has overhang. They want fullness but want to cheat and get it in a small box and/or with small drivers. This doesn't sound at all like what I am describing...
How flat are the AGs/aren't they?
Hi Keith,
What is this a list of? Amps you gave heard and liked along the way?
The 2-3k is a little funky but honestly they aren't too bad. On axis or even close to on axis has variance only topping maybe 5db, mostly 2-3db which is not so bad. A higher impedance source may help some. It's when a graph looks like that but you realize it's set at 5db increments so every little variance is 5db or more, that I get worried. I am slightly surprised it isn't smoother though.
you might be interested in John Devore's measurement comparison to other high efficiency speakers here:
https://parttimeaudiophile.com/2013...utan-o96-stereophile-measurement-comparisons/
Peter, could you elaborate on this?
Keith, correct me if I'm wrong, but my take from all this is that no one spkr you've auditioned has been a slam dunk winner over yr Devores, esp when you take the eye watering price tags of the competition into account.
Surely you should only consider the move if one of these spkrs had comprehensively trumped yr Devores, not just offered some advantages.
And maybe you'll conclude that you just really really like yr current spkrs.
May I ask what is the size of your room, Dave? I have a mid-sized room of 24 x 12 (13.5 at small window bay) x 8.5 ft. In this room I might run into trouble with larger subs than the 12 inch ones that I have. Fortunately JL Audio allows for "extreme low frequency" adjustment that prevented problems that I would have without it already with the 12 inch woofers; as adjusted (- 8 dB at 24 Hz) bass is excellent in my room. JL Audio recommends its 13.5 inch subs only for large rooms.
But I guess bass depends not just on woofer size but also on woofer design.
Bass bellow the Schroeder frequency is also due to how the speaker couples with the room - and here manufacturers have to guess. Peaks and nulls in this zone can give us a wrong feeling about the whole speaker balance. And we should remember that unless properly positioned most box speakers will show terrible peaks in the main resonances of the room.
The type of construction has a strong influence in bass quality. Houses built with heavy stone walls or concrete will increase bass significantly, creating an excess of bass in some frequencies and nulls, light building or drywall can absorb bass making it more linear, but sometimes absorbing too much in some frequencies.
BTW, IMHO discussing bass without proper measurements is very circumstantial and brings little to the subject. Properly handled, deep bass can make wonders in sound balance perception. However sometimes bass is really a curse!
The main room is about 15 ft wide with 13ft ceilings, but is open to the rest of the house. It's a funky mid 80's split-level with the main living area having the same ceiling as the upper floor. It's an awkward floorplan but for audio it's turned out to be excellent and I LOVE the high ceilings!
For subs, I'm not sure a larger cone is as large of an advantage vs a woofer playing midbass in a main speaker. I've heard multiple 12" subs kill it in a fairly large room with careful setup.
TBH it's really hard to define exactly what I like so much more about my 15" ported woofer boxes in my horns vs the two 7" TAD woofers in my S-1EXs. There is less distortion and better low-end extension, but it's not only that... the 15s provide a sense of envelopment, like the whole house is just filled with sound, and it's more effortless and relaxed vs the two 7"ers... It's also hard to say how much the mids/highs effect the perception, bass has a major effect on how we hear the higher frequencies and I'm sure vice versa is also true. Both woofers are crossed at 400 Hz as well, and I think both are 24 dB slope too... so it might be interesting to use the TAD coax mid/tweet with the 15" bass cabs and the horn mid/tweet with the 7" woofers just to see what happens.
I also think the variance in room size and construction makes active bass a really good idea. I know it has a bad rap because many manufacturers have failed to properly integrate active bass with their mids/highs, but I'm 100% sure it's possible to accomplish a near perfect match. One of the reasons I think AG finally got it right with the Duos is thay don't use compression drivers for their mid horns. OTOH a friend had some older Unos and they truly are the Bose of horn speakers!
