I have seen a paper where they looked at thermal compression and found peaks being compressed by up to 7dB. That will clearly impact perception of dynamics I would think...I think it is a pernicious problem as it creeps in right from the get go...the higher the sensitivity generally the less the effect at a given input power.
Exactly the character comes through regardless of the seeming infinitesimal distortion, which of course is what “character “ really is...
Mickey Mouse drivers as opposed to JBL, TAD etc![]()
Thanks Morricab, but I don't understand how this response answers my questions below?
PeterA said:
Could you then define what you mean by "low sensitivity speakers"? I have heard systems that I would describe as very dynamic which have 90 dB speakers and pretty big amplifiers. Perhaps my idea of dynamics is different from yours. How does one measure whether or not a speaker is dynamic?
Macro dynamics is bam slam, dynamic contrast
Micro dynamics is the slightest shift in music including weight of hand on the bow
Tonal contrast, changing of tone with inflections, also adds to micro dynamics.
You feel like music is covering a lot of ground as it goes from low to high, that is dynamic range.
If you want all of that, get horns, hombre
The reason those "90db" Magicos need big amplifiers for dynamics is the high order, phase angle heavy crossovers they use. 90dbs in this case is relatively meaningless (and sometimes measured into 4 ohms which is fibbing a bit).
I say this as we get accustomed to saying high sensitive speakers are better dynamically, but that's not always been the case in my auditions (see Gamut, some say Boenicke). I think Wilson is considered "dynamic" more because of the upper bass hump that is designed into their speakers not just that they are relatively sensitive.
ALE 7550D..bad precision and terrible toilet role voice coil assy
I even bought a pair to try out
Thanks Keith. Yes, I have heard 90dB Magicos sound incredibly dynamic with the right amplifiers, though I do not intend to make this a discussion about specific Magico speakers. It is clear that there are other more popular brands around here.
I'm still trying to understand how Morricab in particular, and others in general, define "low sensitivity speakers". If it is the case that "it all depends" based on crossovers, how the specs are measured, etc, then it will be difficult to specify a number. I get that. I was just looking for a starting point for the discussion.
Regarding dynamics, I think we all have varying opinions about what is dynamic. Some argue that horns are the most dynamic, and that may well be the case in most circumstances, but I have heard convincing dynamics from a number of speaker/amp combinations. Similarly, there are other attributes which lead to speaker purchases. It is clear that not everyone is a horn/set customer. After your year-long search, it seems that you are not yet ready to make that switch either.
Yes, pro stuff is designed not to compress at high levels and at typical audiophile levels it is loafing along with huge headroom and relaxed presentation. This goes also for non-horn loaded large cones with 95+dB for bass and mids. The lack of strain is evident.Peter, I think there can be different kinds of dynamic sound. While I’ve heard dynamic sound from lots of stuff, there is something different about stuff that leans on the “pro” side.
No that one I haven’t seen before. However, I find it strange that it is hard for people to accept this very real issue with speakers. Not only does it compress peaks it messes up crossover points and each driver will experience the problem at different rates. Most audiophile drivers have smaller voice coils (unlike pro drivers) that will heat up swiftly.
I believe implementation trumps design philosophy every time.![]()
