King Cello is a pretty darn good phono stage
Here's a cool trick I did with some of the tapes a client sent. I don't have a wow/flutter meter so I recorded the test tones into my workstation. The top tracing is a test tone from an MRL tape and the bottom test tone shows the flutter from the client's tape! If you wanted to, you can count the "ridges" to determine at what freq. the flutter is. This determined that the tape was recorded from a less than optimal machine.
Bruce,
Are you sure that it is wow/flutter? Although I can be wrong, as I do not know the frequency of the test signal and can not figure the scales in your picture, it looks more like scrape flutter than wow and flutter. This type of effect also shows in machines having Revox/Studer heads needing relaping.
Bruce,
The 2 graphs were done back to back. Both record and repro heads are new Flux Magnetics ER heads. I took the tapes over to Mike L's place with the same result. I tried them on 3 different machines. Four tapes out of 29 that the client sent had this problem. The freq. is 1k
Just came across these post so don't mean to grave dig posts.
Yup. That^ is correct.
If anyone is ever in New Haven, stop by.
We'll give you the penny tour and we'll give you a preview of our new equipment, if we have it set up.
Thanks for confirming my memory :)
