A whole diff ballgame. Just 2 records in...MORE of everything with a clarity that didn't exist before !Curious minds want to know your initial impression?
…I thought the same but then came the XL Air upgrade…I thought the Safir was "end-game" for me but then I received the CS Port TAT1M2 and as big a leap as the Safir was the CS Port was another magnitude of improvements.
Well, we have a mystery. My dealer and the US importer say you can get the Safir 9 in multiple wiring options. Crystal, Kondo, Cardas, etc...I think it was initially offered in only Kondo, maybe that has changed? My dealer was quoting me pricing not the diff options...
Thanks, I wondered about the dual wire option. I am sure it adds mass inside the arm also, and on the Safir, I think the mass is already enoughI believe Franc has always offered the wire options you mention. The default basic is Crystal Cable Silver/Gold. The options include Cardas Clear, Crystal Cable MonoCrystal and Silver Kondo Audionote Japan. He no longer offers Nordost tonearm wire. I have the Kondo in my 4Point. When he built the 4P that I reviewed I wanted Kondo on the continuous run to the male RCA plugs and the copper Cardas to the female RCA block, so I'd have both copper and silver options. But that combo turned out to be too thick and heavy.
Don't buy the dual wire option, it adds lots of high frequency problems only!Thanks, I wondered about the dual wire option. I am sure it adds mass inside the arm also, and on the Safir, I think the mass is already enough![]()
Any new insights, jfrech?
What is different, how sounds it different?
I spoke to my dealer, I'll start making some small VTA tweaks to see if this addresses my quibble above. He thinks it's VTA and not cabling. (he sold me the Transparent phono cabling...)Hi, now that I have a few listening sessions, I must say I get what the other owners are saying. It's not one thing is better, it's everything is better. I could check every box up and down the usual list.
My only quibble is, and I am suspecting this to be a cabling difference, missing some body and weight on the notes. This is a strength of the transparent cabling that I own (and not using now on this arm b/c it's hard wired with the Kondo Silver). That said, the Kondo wire is very naturally revealing, no hint of brightness, bass goes deeper than my Transparent. All of this is REALLY hard to know is it the cable? is the setup? Am I missing the easy VTA on the fly adjustment on the 4p. I think I'll start playing with VTA on diff record heights, it's not hard, loosen one screw, twist up or down, tighten one screw. This could the issue right here as I was actively using the 4p on the fly VTA adjusting...
More to come...
Added mass is the least of problems introduced by dual wire. The biggest issue is increased resistance to horizontal movement of the arm.Thanks, I wondered about the dual wire option. I am sure it adds mass inside the arm also, and on the Safir, I think the mass is already enough![]()
I found with my 4Point 11" and using the excellent Wally Skater tool that the tonearm wire was having a large effect on the % anti-skating measurements and unwanted natural horizontal forces (with no anti-skating) acting upon the tonearm.View attachment 114069
Looking at the standard 4Point, the wire emerging from the yoke that goes into the cable will flex as the arm moves horizontally. The Safir uses a similar wiring arrangement. The weight of the yoke (which also holds the arm tube) is supported by a single point into a sapphire bearing for horizontal movement.
If the combined arm wires were thick or less flexible (or the yoke very light in weight) I can imagine how that could contribute to torque affecting tracking and anti-skate. I'm not seeing or hearing evidence of an issue in the bi-wire implementation from Kuzma. It 'seems like' the mass of the yoke is sufficient to be unaffected by the flex of the wire. The silver Kondo is four 0.05mm strands - very thin.
By the way, Stereophile had an article where you could download audio samples so you can listen to the different Kuzma wire offerings.
Do Tonearm Cables Make a Sonic Difference? You Decide!
Hello jfrech.Hi, now that I have a few listening sessions, I must say I get what the other owners are saying. It's not one thing is better, it's everything is better. I could check every box up and down the usual list.
More to come...
Hello all,
I was hoping those that have experience with the various Kuzma Arms could help me understand something....
If I recall correctly, when Mr Kuzma introduced the VTA tower on the 4 point, 4 point 14, and the reference 313 VTA arms that many found that to be an excellent addition, being able to adjust the VTA while playing or not with very easily and repeatably adjustments. All this, of course, without any loss of rigidity and with 0.01mm accuracy of adjustment and zero-play.
I realize that the vast majority feel that the Safir is quite superior to his other arms, However, now with the Safir, the VTA tower is no longer available. I'm wondering...
1. Why Mr Kuzma didn't include this option?
2. Do the owners of the Safir miss the ease of adjusting the VTA whether the arm is playing or stationary?
3. For those of you who once had the VTA tower, would you actually change the VTA when playing different weight records or simply leave it set in one common place? As if the novelty of the VTA tower wore off?
Thank you in advance for sharing your thoughts and experiences with me.
Best wishes,
Don
Hello bazelio,We discussed this earlier. Essentially your supposition of "without any loss of rigidity" associated with the VTA tower is incorrect. This is the likely reason for its omission on the Safir.
PS I, for one, only use the VTA tower on my 4P11 when initially aligning the cartridge. I would be just fine with a less convenient VTA adjustment mechanism.
