Which EL34's have you tried?I have tried the following tubes and perfer the F2a Siemens
KT88 KR
KT 170 Tung Sol
EL 34
F2a SiemensView attachment 90544
Heating scheme and voltage drop.Lukasz asked us all a question when he was at my house...."how is it that if all a rectifier does is take a sine wave and convert that signal to a flat line , why do they sound different. I don't have a clue but here I amin a tube rolling thread and trying to contribute.
I know the Tak. AlRainbow had it from 2018. Luxury packaging, but it kinda freaks me out as it seems like a coffin. LoLThanks Norman ....for me it's my ears and this was immediately apparent
FWIW the bamboo box that the tube came in was so well manufactured with top and bottom so precise that it was like one of those puzzles where you have to figure how to open the box.
I know Lukasz advocated for leaving one's system on and I had been following that but now I understand when guys like alrainbow says his is turned off to preserve tube life. In this case I am going to do as Al does and turn on and turn off when done
what about leaving on but mutedI know the Tak. AlRainbow had it from 2018. Luxury packaging, but it kinda freaks me out as it seems like a coffin. LoL
The NOS WE 274b will give it a run for the money....but the Tak is imperious.
No, you should leave the Dac on, just swap out the Tak for an el cheapo tube recti or a SS recti that costs like $20. Don't leave the expensive Tak recti always running (at full power, unlike the other tubes).
Hi NormanI know the Tak. AlRainbow had it from 2018. Luxury packaging, but it kinda freaks me out as it seems like a coffin. LoL
Fine too. The other tubes run at 5-10% of rated capacity, while the recti runs at 100%. So you weigh the damage of hot and cold recycling with recti vs 100% full run while on. The equation is clear for the other tubes...pros and cons with the recti. Hence my compromise is a SS recti to keep the seat warm. LoLwhat about leaving on but muted
Cough, cough....no end to the price limit is there for WE. I recall 10 years ago when one could bet a pair of 300b for $600 lightly used.Hi Norman
My search started at the WE but I bolted at the entry point which for a used tube with who knows how much life left was $2200
Even with volume up and amp on, but I always MUTE out of an abundance of caution...no need to turn power amp off though, when the preamp and/or the Horizon is muted.and just to be clear you can change a rectifier with amp off and DAC muted??
Bal Mullard xf2Which EL34's have you tried?
Just curious- are you running balanced or single ended?
Did you ever try 5U4G Tung Sol ? CuriousThe Tak has been my preferred rectifier in the Pacific.
Keep it for your Horizon rectifier. What I find important about it is nothing grabs my attention. Top to bottom linearity.The Tak has been my preferred rectifier in the Pacific.
