Could you please provide the name of the preamp you found to be copacetic with the 242 in your Pacific? Thanks in advanceI may have a gently used pair to sell soon, once my new Horizon settles in and I can happily send the Pacific back to Lampi with its original tubes... They are the clear best in my Pac, once I found a preamp that could handle them.
The 242's worked like a charm with my current CH Precision L10 - - magical!Could you please provide the name of the preamp you found to be copacetic with the 242 in your Pacific? Thanks in advance
Surprised to hear the Ref 40 overloaded. It has a high overload margin — 20V. I seriously doubt the Pacific was putting out that high a volume using KR 242 tubes. Did you have your Pacific on high gain?The 242's worked like a charm with my current CH Precision L10 - - magical!
I got overload distortion when I tried them on my previous ARC Ref 40. Maybe that initial Ref model didn't have the overload margins, either. I also tried them with my D'Agostino Momentum HD and had a similar distortion problem.
I'm not sure. My Pacific did not come with switchable gain.Surprised to hear the Ref 40 overloaded. It has a high overload margin — 20V. I seriously doubt the Pacific was putting out that high a volume using KR 242 tubes. Did you have your Pacific on high gain?
Not a good match. Neither technically nor in terms of circuit and sound philosophy IMO.I will try it with Thomas Mayer 10y later this year.
Hi!Regarding the amp, we were trying to check what kind of drive the speaker requires. It requires a bit of push pullness and oomph. It was not a compare of sonics of amps, but more to test the requirement of the speaker.
Your comment on neither technically nor in terms of circuit...can you please clarify?
Hi!
If the speaker needs more drive you need to check the power amp not swap preamps that does not make sense.
The DAC uses DHTs in cathode follower mode and I assume capacitor coupled outputs unless it uses some DC servo scheme. I am not implying that such a circuit is bad, it is a matter of choice. My preamp uses a very different choice which is sonically very different. No feedback no cathode followers, no coupling caps. These are opposite philosophies.
Also that DAC has a very high output level. Wie the 10Y is very overload proof it is designed to work best with typical line level values. If customers insist on using sources with such high output levels I employ step down input transformers to reduce that level to more practical values.
best regards
Thomas
ok sorry, did not read the whole thread just your post where it mentions the DAC and 10y. my bad
Has to have it I would sayYou are saying that your Pacific does not have 2 switches underneath the top cover which can cut the output by x dB (I forget the amount)?
How's it going buddy?Worked very normally with my Ref6 and absolute no issue with Tobian preamps...
Increasingly, DACs are produced that generate fairly high levels. My solid state Chord Dave produces quite a high voltage output in DAC mode — I think it might be 6V. One reason is that many DACs are used in lieu of preamps and manufacturers want to provide plenty of drive for a variety of amplifiers. I think the safest option is to get a preamp with gain matching or one with high overload margins.Hi!
best regards
Thomas
