Has anyone tried a EL34 tube
EML 25th anniversary globe (solid plate) 45 $1,800/pr negotiaable (unobtanium, may already be gone)
Norman liked the EML 45 mesh AGs on voices quite a lotThe EML globe anniversary solid plate is quieter and more nuanced than the gone anniversary mesh or the Lampi 45. This is better on Greg's horns when listening to violin and piano. On vocals the mesh are better.
in the upcoming all new Atlantic 2 DAC. TRP as Lukasz calls it... Tube Rollers ParadiseYou can play this in Lampi? I love el34 and 84 in amps
Exactly that one, yeshttps://shop.best300b.com/products/kr-5u4g-rk-limited-series
Is this the version I should be getting?
Good to know (about the solid plate version).The EML globe anniversary solid plate is quieter and more nuanced than the gone anniversary mesh or the Lampi 45. This is better on Greg's horns when listening to violin and piano. On vocals the mesh are better. In the KR preamp, the mesh gave a bigger stage and air but were noisier so I preferred the KR 45, which I don't like in the Lampi at all
The normal EML 45 mesh i have is the most noisy and sensible for emi of all the tubes i have.
How about the PX25? I am bit sceptical since my PX4's are ringing a lot, very mycrophonic.
At first it sound like wow, nice decay on piano etc. But than i found out it's the tube..
Yes, but i meaned are those PX25 also ( a bit) noisy?I like PX25. Do you now have AS or balanced?
Or maybe somebody else can tell?
Spec sheet doesn't mention what tubes the DAC was tested with. I just put EML 300B XLS tubes and they are significantly better than the PX4s. They work well with both rectifiers (RK5U4g and Takatsuki). Both rectis are still burning in so things may change over time.If I may ask what does the spec sheet say for tubes tested
