Black
And heavy. And it is a Amp which has the Status „Reference“. Well, to make a very long Story short, the Status, it is true, indeed. It is a Hybrid Design with 1 Tube (6922 Triode tube), maybe it makes the difference, who knows. What strikes the Listener after the warm up is a total different kind of the tonal color compared to other Transistor Designs.
This thing simply sounds different. It gets all of these little details right from the sonic structure and tonal differences.
The amp can be matched to the connected Speaker, at the rear is a switch where you can choose the load, 1-6? or 8-16?, when your Speaker is in between, don't worry, listen to each setting and choose the one you like best. There is definetly a sonic difference between these, but it depends on your X-Over and Speaker in general.
It is pure Class A, healthy, stable and like I wrote, not as dead or clinical sounding as most other similar Designs.
My prior Listening is back to the Time where RCA Living Stereo were recorded, Mercury Living Presence or Decca, Londons...mostly Classic ballet music, very dynamic, complicated from Soundstage, Staging, lots of different Instruments, good channel Separation and Speaker Chassis are neccessary to get it....
Most audiophiles are looking for Artifacts like more Bass, Black background, deeper Soundstage and so on...I can't comment that (it would be easy to support that but I don't like these kind of descriptions..) but what you can hear immediately is, there is something totally different going on in front of you.
Being a visitor IN that Playback Performance (will not work with Rap, HipHop or similar, sorry)...Clear Emotion?
It breathes life into the Performance, it combines technical expertise with emotional intensity, delivery lightning strikes of deep, fast, ultratight Bass (my listening tools are 8?, 93dB, simple X-over speakers ... Easy to go speakers) and a remarkable expression of bloom and air with no loss of detail or control. The impression of a liquid-sounding Playback will come to new life, yes, in a way, the rightness of the musical flow is indeed obvious.
I am careful with the word musicality because this word is used too much from inferior or wrong sounding units, but when your software is one of the better recordings, you are indeed a part of a timeshift. I modified my units with a few higher quality parts, mainly input and speaker terminals...but didn't touch anything from the Layout. The Sound is faultless in every area of Performance, Soundstaging, Imaging, dynamics, harmonics (this here is key), frequency extension, solidity, outstanding transient speed, Clarity...you name it.
Maybe this amp will get some limits with inefficient speakers, can't say, don't have such. Efficient speakers can make life pretty easy and allow the connected amp to shine. Good amps are able to tell the Listener some total new stories with uncanny humanness and realism. This amp is one of those. It has its own ability to respond to a signal, amplify it and going out of its way. I replaced the stock tube with Amperex, very nice improvement, finally I landed with Telefunken from 1970... Linear, straight, clean, quiet.
Probably I can write their abilities in one Sentence:
There is something which makes you refuse to shut them off.
Or
2. sentence
they make you almost forget that you are listening to recordings...
