Lyra Atlas Pics
Would you mind contrasting the sonic differences between the XV-1s and the Atlas?
XV-1, can you describe the sonics and how they differ between your Atlas, XV-1s and A90? Thanks.
Hmmm, tuff one gents - all cartridges are wonderful, so bear in mind will no doubt may sound different in different systems
In my system, the XV-1s is the genuine all rounder - does everything well and to me sounds like what the best tube gear does. Slightly generous bass which gives the music a foundation with a little tonal meat in the mid range with a really nice airy treble. the XV-1s sounds excellent with tube and SS phono stage. go to cartridge for rock n roll and not so great sounding alternative albums.
the A-90 in comparison is a little laid back in overall music delivery and not seem to have the bass drive the XV-1s has - more a intimate jazz cartridge than rock n roller. Tracking is not as good as the other two cartridges. the A-90 stylus is closer to worn than not, so really does not get much use now.
Atlas is like a formula one car, fast and pure top to bottom with a tight bottom end. No tonal meat in the upper bass/midrange with the Atlas. Excels with all music except for lean rock n roll/alternative when it can sound a little threadbare. Early Bob Dylan or Beatles will sound better with the XV-1s or A90 as they add a little tonal meat. Clarity when playing complex or multi tracked music is SOTA as the notes seem to start and stop with ease and lack of overhang. Loves electronic music to the max. Loves my tube phono stage as it brings out the best qualities of the tubes including treble extension and quickness, whereas with my SS phono it seems to highlight the weaknesses more and sounds a little mechanical.
When the time comes, I will definately have the Atlas and XV-1s rebuilt however not the A-90. 1200 hours or so play time for the A-90 vs 2500+ with the Lyra and Dyna.
Bottom line, having different cartridges on different tables gives you the opportunity to enjoy all music types with little downside.
BTW, I just bought the Delos cart for another flavour. WOW, for the $$ it really is a bargin. All the Lyra attributes of clarity and speed with a little bass weight. I actually prefer it to the Kleos which is more refined but lacks a little life in the upper frequencies imo.
Reactions: RickS
Thank you SO much for this, XV-1.
Based on your descriptions, I will remain much happier with my XV-1s as I do find it sounds great. It's important to me to have meat on the bones (as I do play the Beatles!) and still have good air on top. Especially since I use a SS phono stage.
Thanks again for taking the time to describe the differences.
You need a 2nd arm on the Raven. Then you can have it both ways :D
The xv-1t has intrigued me as from reviews it seems to have a bit tighter bass , better clarity but still that airy dyna sound - but bloody expensive and cannot afford 2 x 10k carts.
I found some pure Copper head shell cartridge clips that are Rhodium plated. Seem to match the pins on the Atlas . Much better than the cheap brass ones
Thank you XV-1 for that detailed description. I'm surprised about the A-90. I had thought that was near state of the art with ultimate resolution, clarity and lack of distortion. I had one but sold it before having a chance to listen to it. I also was not aware of the considerably shorter stylus life.
Don't get me wrong. The A-90 is an extremely good cartridge and more transparent than the XV-1s, but its laid back slightly reserved personality makes the XV-1s a more musically enjoyable cartridge.
I have always found the HiFi news review of the A-90 represents a reasonably accurate view
http://www.hifinews.co.uk/news/article/ortofon-mc-a90-pound;3000/9611
The stylus life for me at least is a game breaker, so I will never buy a cartridge with such an extreme stylus profile as the replicant 100.
Are there anybody in here that has tried the Atlas with a Triplanar arm? Any thoughts?
I have. Works great. I had a triplanar before my current schroder lt arm....
Would love to get your input on my post over hear given your experience and setup:
http://www.whatsbestforum.com/showthread.php?16813-Lyra-Atlas-or-Koetsu-or-something-else
Thank you!
I now have an Atlas in my TriPlanar, and a Colibri in my 4Point. Completely different sounding cartridges that works in a great symbiosis on my Raven. The best of both worlds, perhaps? :eek:
I have had Atlas to try for a while. It has been a beauty. Here it is seen as mounted to Graham Phantom B-44
Where have you guys ended up on loading the cart?
Mine is at 670ohms...but this will vary by phono stage and cabling that's used...
Wow, in a few weeks I have had my Atlas for 3 years.
How time flies:cool:
Atlas loaded at 500ohms on both my ss or tube phono.
Been using SUT until now, but bought myself a Whest phono stage for use with the Atlas. Could not really get it perfect with the tubes, to bloomy for my acquired taste. That just why i wondered, keep em coming!
Have been setting up the cart with use of both USB-microscope and Adjust+ software, and the new angle technology really proves to work out well. But ONLY if it is proper set ut, the SRA shows 92 degrees when the VTA is 90degrees, and so on......
Maybe the diaper shows the dark shavings that indicate the needle has turned into a cutter rather than a player.
It does, and prevents the shavings from entering the motor.
On the older versions the rice paper is close to hitting the vinyl, but on recent it is firmly wrapped to the housing.
