Magico introduced the Q series subwoofers
LL21
14,423
2,516
1,448
I said to use 4 two double stacked with,,,,WITH the JL electronic crossover Sir
Please read what I wrote.
I did not say it was better than what I have not heard. However 30 k for a single woofer with no electronic crossover is a lot of KASSSSSSH
I thought QSub had 2 woofers firing in opposite directions to help cancel out some of the internal vibrations? Plus internal amp and electronic crossover?
EspenL
73
30
250
Norway
yes that is correct it is a internal amp LL21
Espen
Elliot G.
3,325
3,041
1,910
Fort Lauderdale, Florida
www.bendingwaveusa.com
Elliot, Whose talking about graphs and expensive machines? I believe first and foremost in listening. If someone can support great sound through a description of the science behind the design, I'll pay attention and learn something. I was just asking you about cabinet vibrations and stacking sealed enclosures. I put my hand on a subwoofer or main speaker cabinet and see if I can feel vibrations. I also listen to hear distortions from cabinets.
I did try some JL F110 subs in my system. They were fairly inert but not perfect. They sounded fine but after a great deal of effort to integrate them with my speakers, I decided that they ultimately detracted from the overall clarity of my system. Even though I got a pretty good deal on them in order to try them in my system, I took quite a hit when I tried to sell them. Perhaps my opinion would change if I heard them stacked and properly set up in a dealer's listening room.
Ok, a 110 is not what I was referring to. I have used two f-113 on each channel stacked on top of each other using JL's new electronic xover and matching device.
Just because you feel a little vibration doesn't mean there is a problem Sir.
I am not saying that the Magico device is wrong or bad but probably a lot of overkill.
Woofers for music should be used in pairs number one and when you use them in a line source configuration ( stacking them) they are many times better. The sound stage gets bigger and deeper, the rooms will disappear and the bass is tighter and goes lower.
Im sure if you used 4 of theirs it would work as well .
My solution is under 20 k and is drop dead amazing.
That was my point.
I am not sold on the Aluminum BS and have heard speakers made of many materials that work well,
When they make a Stradivarius or a Les Paul out of Aluminum and it sounds great then maybe I will drink the coolaid
PeterA
12,650
10,903
3,515
USA
Very interesting response. I'm not selling anything nor do I like Kool-Aid.
Aluminum is certainly not the only solution for a good speaker enclosure, but consider this: The wooden body of the Stradivarius instrument in fact resonates creating just the sound many of us so admire. A mechanical device like a serious loudspeaker, is an entirely different thing. It is designed to accurately reproduce the sounds embedded in a recording. Ideally, I would prefer that the loudspeaker not add its own colorations to the sounds it is trying to reproduce. Transparency to the recording depends on low distortion. Cabinet vibration causes distortion and makes it less likely that the speaker will accurately reproduce the sound of the Stradivarius.
Elliot G.
3,325
3,041
1,910
All cabinets have vibrations and a Q point. Aluminum is just different than acrylic or wood. I for one can not tell you that just because it seems it has less that it sounds better particularly on frequencies below 60 hertz.
The room has much mor eto do with low frequency response than a vibration in a cabinet.
4,700
The main problem is that all devices have their own distortions and we do not know how to properly correlate measurements with sound quality. Simple parameters based in RMS figures are not enough. As far as I know Goldmund were the first to use aluminum boxes with complex dual metal bracing to damp its intrinsic resonances, and in the 80's there were some debates on the subject in European audio magazines. Unfortunately it was before the internet, and they are not easy to find and consult.
I am not buying such expensive subs, and have not listened to them in adequate systems, so my two cent opinions on subs is based in my analysis of other people reviews and reports, and should be considered as just my poorly supported opinion. But when I read that some people consider that IB are the best sounding existing subwoofers, I can not avoid thinking that these houses are not built with aluminum slabs, and most of them have wood floors.
BTW, the best sub I have listened to was by far the Hartley 24" used in a Mark Levinson HQD system. It was fabulous, but each sub weighted more than 300 kg with a volume of 500 liter.
cannata
510
64
263
Italy
Aluminum is not just different, it is indeed, if implemented right, a MUCH better material to use, in particular for bass enclosure. It is really simple math, your ears can tell you what you want to hear, that does not change the laws of physics. You will have to excuse me, I am not about to enter a debate about that, you sound like a guy who will dismiss global warming, if he sees fit ;)
LL21
14,423
2,516
1,448
I am no techie, but going back 20 years in my own personal systems, whenever I found a way to lessen cabinet vibrations, I generally liked what I heard. Greater signal density/strength is what I recall hearing the very first time I did it with my Celestion SL6si's. The same has applied to my X1s and Velodyne.
Does a solid aluminium cabinet help reduce vibrations because of its inherent ability to resist the internal pressures of the sub better than other materials? Intuitively, I could imagine the answer is yes (and at significantly greater cost)...but I equally suspect the end result is still about the overall design/implementation (NOT simply using aluminum) because I presume those pressures internal to the box also have to be managed inside (even if they are not surfacing outside the box thru the aluminum) so that they do not interfere with internal amp, cone movements, which are probably all vibration sensitive, etc...
PeterA
12,650
10,903
3,515
USA
That sub is waaaay too cheap, the way it looks! But it needs a "Q" to shine in all its glory ;-)
I wonder if they sell many of these Qsubs. Perhaps they should introduce an "S" sub of slightly lower quality to mate with their S line of speakers. I can see a curved aluminum tube enclosure like the one on the Ultimate 3 horn speaker.
stereo
407
4
143
It would cost too much money to develop another sub driver for a S series... and all of this to build something not as good as Q-sub
I heard they sell pretty well... Maybe because they sound pretty well :)
The S5 looks so small compared to the sub on the pic!
nirodha
683
305
1,625
True! But then I have never been a fan of the S-series looks. Prefer any "Q-design" look. Like everything...a taste thing.
LL21
14,423
2,516
1,448
I'm no techie, but I do find it curious that with the Q18, the edge of the cone is beyond the edge of the cabinet...whereas in the Q15, the edge of the cone seems to be well behind the edge of the cabinet, and in fact you can see where they have carefully shaped the edge around the Q15 cone...why the difference?
andromedaaudio
8,469
2,821
1,400
Amsterdam holland
I can only comment from what i see , but i suspect the larger cone has a substantially longer excursion than the smaller sub , the much longer /larger rubber surround with which the cone is connected to the unitframe allows that , with such a large rubber surround one would need a very thick alu alloy front plate to have it not sticking out
What magico does is sandwiching the cone between a front and a backplate so removing the need for a bolted unit in the frontplate , the designer likes a smooth front of the speaker no holes and screws ideally , in the S 5 that was probably not possible due to the thinner housing 14 mm iirc, the S 5 is built to a certain pricepoint probably
LL21
14,423
2,516
1,448
Thanks!
Blazar
20
2
The odds that this sub will beat multi-driver DIY subwoofers made by guys in the DIY forums is ZERO. Anyone who thinks otherwise just doesn't know any better. I owned JL Audio Fathom 212's until recently, and even those are simply wimpy compared to what I was able to produce form DIY subs coupled with great amplification.
I don't doubt that the Magico's sound good, but their output claims are kinda suspicious and certainly equivalent or better overall bass can easily be had a for a fraction of the asking price.
Don't forget that one or two of those subs will be UNLIKELY to be enough to get a linear in-room response. Anyone that can afford these and want "the best" possible sound should but at least three to four of these in order to get in the right ballpark.
Blazar
20
2
If we are talking about producing a sufficiently rigid structure for subwoofers, there is no reason to stop at aluminum... some of us in the DIY crowd simply create a custom concrete form around our enclosure... problem solved for vastly less money.
I would be really impressed if the rooms that this type of speaker are used in are sufficiently "bolted down" so as not to have vibrations form the bass rattling things.
FrantzM
29
405
I am with Blazar on this. Nothing against Magico, I am fan after all
For the cash outlay these Q woofers represent, one can do better with more subs.. There are some excellent commercial subs out there ... A quatuor (4) of JL Fathom 212 is about the price of one of the Q15, the law of physics are in favor of more subs'l I will concede that the DIY route is not for every one but it can/will lead to superior results.
This is a fact: while there are chances that one (1) sub can/will improve things, the odds of this being optimal are very small. One usually needs more than 2 subs for smooth in-room bass response.. So far we, audiophiles are adverse to that notion... of multiple subs but things are changing.
Funny I was also thinking about concrete enclosure as well... I know that my subs will be either DIY or likely HIDFY (Have It Done For You) or Mark Seaton's Submersives, they won't be concrete :)
Welcome Blazar!
PeterA
12,650
10,903
3,515
USA
Could you post a photo of one of your concrete subs? What size is the driver and how do you amplify it? And finally, how heavy is such a beast? Thanks.
