Good point.
How'd those BGs work out?
Hi,
That project has been put on hold temporarily. But Rich's Ampex with BG's that I spec'd will be running next week,stay tuned.
Good point.
The very same thing happened to me in an audio club situation: 2 very different systems were played, the first which created/retrieved a very airy, realistic ambience of the recording space, nicely holographic in character, the second the classic hifi sound, in your face, intense, sharp, the sound obviously coming straight at you from the drivers. I turned to one of the leading lights of the club, who does reviews for a well known audio website, and said, "Remarkable how the second failed to get anywhere near the first in SQ", and he said, "What do you mean? Obviously the second is the better system!".
After recovering from falling off my chair, I pondered this. In hindsight, this was all about expectation: the second system behaved exactly like a conventional setup was supposed to behave, and therefore was the better system: it delivered an anticipated, desired result. The first system was disturbing, it was being "unnatural", therefore was wrong.
So we may still have quite some way to go ...
Frank
I've heard all of that many, many times before, micro. I used to believe it myself. Then I tested it, and it simply vanished.
Tim
I do enjoy reading these discussions. On one hand you have folks who don't understand electronics claiming that we are not measuring everything and the other those who do understand electronics claiming we do. (...)
Science cannot be denied,.
Yes, but you tested it in conditions and with a methodology that would lead to that conclusion and naturally compromise the results. I am sure that you also have heard (read) this many times ...
But it is --- regularly, frequently and consistently on these threads.
Well the only relationship between real science and what is discussed here is purely coincidental.
Thanks, Lee, I appreciate those comments: I probably didn't mingle enough with a variety of audio people to appreciate that there was such a divide ...There have been many discussions over the years in many different venues that consider this topic. Some audiophiles prize tone quality, realistic dynamics, and overall volume capability, while others value the sense of space and ambient cues more highly. I know, a proper system does all those things correctly, but the real world interferes and compromises are the rule. Thus, the "camps" are born.
Lee
Sorry to possibly disturb you again, Tim, but you're touching upon a key element of audio here that I would emphasise is extremely important. You're surmising that when you quickly switched between two different circumstances that a seeming difference disappeared, and that that was evidence that there was no real difference in the first place.This includes extensive listening over time to a wide variety of recordings, finding myself hearing things that, upon returning to quick switching, vanished.
Perhaps part of the problem is the use of the word "quality": that to me is directly associated with a lack of audible distortion, in the conventional electronics sense. With real sounds, there is normally no such factor in operation, unless perhaps one has defective or impaired hearing. If I move closer to or further away from a real instrument, equivalent to changing its volume, the general impression for me is that the sound it makes becomes more or less intense, rather than change in "quality".The point is that the science being discussed here right now -- that volume effects quality perception and that auditory memory fades very quickly over time -- is very well established and well-supported.
http://scholar.google.com/scholar?q=auditory+memory&hl=en&as_sdt=0&as_vis=1&oi=scholart
I'm sure if you bother to read any of that you'll be able to find things to object to. It was a quick Google search and I haven't read it myself. The point is that the science being discussed here right now -- that volume effects quality perception and that auditory memory fades very quickly over time -- is very well established and well-supported. There is a lot more out there if you care to look. Google is your friend. Unless what you really want is to avoid any science that might challenge your beliefs.
Tim
I will say, hear, hear! And add, the illusion has a much better chance of effecting that reaction in our brains if as much information is fed to our ear/brain sense as possible, with minimal distortion. Easy to say, damned hard to do well enough!The purpose of a stereo is to create an illusion. While that illusion is created outside our head. The effect is in our brain. Our head can never be wrong. The only thing the person who attempted to create the illusion can do is scratch his head and say well that was not the illusion as was striving for. It's the illusion maker who must change.
Pray tell Tim what you ever did that was scientific?
This is going to upset some, but I would propose that in fact there WAS a difference, in least in some of these situations, and that the difference DID disappear, and this was a real occurrence. Huh?! Well, what I talking about is that the ACTUAL PROCESS OF SWITCHING itself altered the nature of the electronic environment that the system was operating in, which then altered the SQ. Hence you weren't only testing the difference between two situations but also the effect of switching between them.
This is all too ridiculous, I can hear people saying
As regards the switch mechanism, both its inclusion AND the impact of the switching operation could be relevant; I have certainly heard the effect of both instances at different times. I'll let the comment about the metaphysical thingy go through to the keeper, as we say down hereExcept for the time/space/ear/brain continuum thing, I don't think it is ridiculous, actually. But I don't think it accounts for what I thought I heard, or what audiophiles consistently report hearing, either. And I don't think it explains the fact that they, even I, almost always heard something obviously better in sighted, long-term listening that almost always becomes something questionable to inaudible when subjected to volume-balanced, rapidly-switched and, particularly, blind listening. Is there something in Heisenberg's Uncertainty Principle that would explain why, in high-end audio, the principle never adds, it never removes a negative, it only seems to subtract something the participant wanted to hear?
Tim
First, you don't hear electronics (you don't hear current and voltage, but the results of those things as they wiggle about a speaker, or the results of how they wiggle because of the way air moves across a microphones transducer.
If you change the electronics, of course you change what comes out the speaker.
The goal of an amplifer, be it one stage or many, is to put out an amplified replica of what went in. We do that routinely and at far lower levels of distortion than you can hear.........than any one of you can hear. Note I said hear, as what your brain does with the information is another story unique to you and me.
If you hear a difference when you swap out an amp, then it is because you did not make a replica:
obvious, but you changed:
amplitude.....look at it on a scope..easy
phase.....look at on a scope as well
harmonic spread.....look at it on a spectrum analyzer (linear or non linear distortions)
do it with music, do it with a pure tone (that is a sinewave by the way), square waves, triangular waves, I don't care.
The issue why you hear differnces in amps and preamps and all such stuff is that they affect these things differently. They do not generate an amplified replica but they add or subtract from it. There is no magic.
So, as an example of phase effect, if the upper frequencies are slowed down a bit and the lower are allowed to pass earlier, you get that "phat" tube sound....but you can get that "phat tube sound" with solid state...if you use a transformer as well....no magic...but surely that "phat" sound does sound nice with many types of rock and jazz and small scale instrumental stuff.
What measurment affects what.....I will tell you, the recording is the biggest effector of what you hear on any given system, one can record in ambience, width , depth, whatever you want, even a dog barking 50 feet to the right of your speaker if you want. But electronics has NO CLUE itself of what the recording means when it pushes the air at the speaker air interface....NONE. Electronics job is to simply replicate the input signal and its the transducers job to simply replicate the electronic command...but we all know thats where things fall down fast.
If I perform just a sinewave THD test on a piece of gear, and not look at phase, then one gear will shift phase say 50 degrees and the other 120 degrees but the sinewave test will not reveal that because it is not looking for phase change.
You can't take any one test, except for a null test, and declare that no other parameters are different. In any case, at some point, the differences in amplitude, phase, and spectrum are so small that none of us can hear them, and that seems to be around 85 or 90 db in a normal home environment.
Tom
Just to expand:Do we agree on the following?
1. That there are measurements that tell us extremely well what we *could* hear. Take the frequency response measurements. If it has a dip of 2 db at 5 Khz, surely we all agree that is audible and the thing that told us that was the FR measurement.
2. That measuring is not the same as understanding. If I ran the above measurement point by a random person on the street they would surely not be able to make the determination I just did. So we need to separate knowledge of interpreting data from ability to gather it.
3. We all want single numbers of simple concepts of performance. Take miles per gallon. There are two numbers that were just revised in US because they were too misleading. Even with revised number is likely to be wrong for my commute to work. So we should also accept that in audio, coming up with single numbers or graphs should not be a prerequisite for understanding audio performance.
