It might as long as you have the same source files they started with before the conversion. For example, the Doors "Infinite box set" was resampled to DSD 64 from the 24/96 PCM files that were created from master tape for the "Perception box set" They used the Weiss Saracon software. I prefer the 24/96 Perception box set resampled to DSD 64/128 and 256 with HQPLAYER, over the Infinite box set played natively. But to be fair, they may have applied a bit more EQ to the Perception releases.
http://store.acousticsounds.com/d/83212/The_Doors-Infinite-SACD_Box_Set
And BTW, it's not freeware. Just a free trial. It cost's $140 to buy. But it can enable lower priced DAC's to sound like DAC's costing $1000's more. So may just be the best deal in high end audio. And they are very close to having integration with Roon. This means once ready, the best GUI yet (PC and mobile app based), with Tidal integration, can be processed through Jussi's engine. The best of all worlds
You can follow the progress here:
https://community.roonlabs.com/t/hq-player-integration/1656
Another one I'm on the fence about buying and comparing is the DSD 64 version of The Oscar Peterson Trio's "We Get Requests". It was sourced fro 24/96 PCM files that were sourced from master tape. I have the 24/96 version and sounds stunning resampled to DSD 256 via HQ player.
http://store.acousticsounds.com/d/9...t_Requests-DSD_Single_Rate_28MHz64fs_Download
