Munchen High end show 2022
I m going 19 - 22 may to the show in munchen
Who s going?
What brands you wanna hear ??
Yes, I heard the smaller version (same as in your picture) at the Klangschloss here in Switzerland in April driven by darTZeel. I think they were driving it too hard there because it got weirdly shouty with some frequencies like the bending wave driver was getting chaotic in motion or something. I heard the same bass integration problem there as well though. It is an active bass and the texture and damping is totally different from the rest of the speaker.
I heard it too at the Klangschloss and my impression was similar to yours. When I heard this speaker at the High End in Munich it was similar, it just sounded a tad better probably due to the amps by Riviera Audio, which I like a lot. I used to have their smallest integrated/headphone amp.
Reactions: morricab
Danish actually ! Even worse ! Could not get information from Shazam, who the artist is. Sounds like Terremoto De Jerez. Do you know Brad ? My Flamenco collection is limited to a few albums. :)
Not really sure...he mentioned something but that it can't be found on streaming services.
LOOK! no shaky cams ( found footage movie) and roll off after 80hz! :D:D
With the usual caveat of relatively tiny inexpensive computer speakers reproducing big expensive speakers, this sounds pretty darned good. Perhaps a touch bright--hard to tell--but very "live" sounding (through aforementioned small cheap speakers).
Was the Rockport that good ?
Best Sound (Cost no object)
I agree - It left me cold. I thought the Rockport Avior 2 with Absolare hybrid amp was a more engaging proposition. I could have happily stayed in that room for hours
Based on that observation - not the speakers fault then - just portraying what its being presented - would that be a reasonable assumption...
It would. In fact I am big fan of Rockport speakers, but I found the CH Precision/Lyra combination to be analytically impressive but a bit souless.
Thanks to everyone .
This is actually what I expected Based on the amps they used . Also Odin 2 did not help.
Rockports pair excellent with many good amps but CH was never my cup of tea.
to cold , to analytical , ears bleeding .
Absolare , Solution, Pass, Emm Labs mtrx , Westminster Lab Rei would be much better to name a few.
Also they tend to play best with Transparent cables as they are internally wireed with that cables.
What would be Lyra best companion from listed above ?
