May I ask what cables are you using?
Of course. I have tried the following:
Unbalanced:
1. DarTZeel 50ohm with RCA connectors
- lots of buzzing noise; unusable
2. Metaxas XLR: this is a 2 pin XLR, so it's not balanced. Sounded great but there was some background noise.
- Pin 2 to Pin 2
- Pin 3 to Pin 3
- Pin 3 connected to XLR connector chassis on the "send" side only
- No Pin 1 connection
Balanced:
3. Mogami XLR from Enoaudio: this is a high quality Japanese cable finished in Germany. It cost about $250 for 10m!
Very quiet, no issues with noise. Sound is 'flat' and lifeless... which makes sense for the price.
4. Luna Noir XLR: originally shipped with 4 conductors:
- Shield connected to XLR connector chassis at each end
- Pin 1 ground connected via dedicated conductors to Pin 1
- Pin 2 to Pin 2
- Pin 3 to Pin 3
Very loud noise - unusable
5. Luna Noir XLR: as above but with Shield disconnected from XLR connector chassis at the "receive" side
Very loud high frequency noise that put the amp into protection mode immediately and blew a tweeter
My media room is powered by one 15A circuit, so all grounds are common [
Edit: this is Not a common ground; even though it’s on one circuit, all ALTAIRA need to be connected together or only one AlTAIRA should be used to have a common ground. This could indeed be part of the problem.]. I use the Shunyata Typhon T2 & Denali 6000/v2 and ALTAIRA ground system.
The cable composition of #3, Mogami, works, so the next step is to get Luna to follow that.
The Nagra HD Preamp has a Ground Lift switch for the XLR output. That would have helped here; but Nagra removed it to improve the sound quality (not sure how, that's what they told me).
Using a ground lift is not really a solution. You’re essentially cutting the ground because there is too much noise. The best solution is to find the source of the noise and eliminate it there.
