Only 100 pieces outthere, equal denon dp 100 or onkyo px 100m both one the best direct drives diffcult to find. It only becomes difficult when you need replace control or controller parts, which are usually no longer available.For vintage Japanese DD, the Denon DP100 would be my pick!View attachment 141668
Only 100 pieces outthere, equal denon dp 100 or onkyo px 100m both one the best direct drives diffcult to find. It only becomes difficult when you need replace control or controller parts, which are usually no longer available.View attachment 141669
Actually, the models were called 100 because there were only 100 of them. But perhaps the demand was greater than expected and they cost like small cars at the time.I think there are more than 100 DP100 produced, probably close to 250 units, at least according to the Vintage Knob!
Whether it is hard to find depends on the timing; it was hard to find a few years ago, but my friends got both of the units in the photo from Japan within a 12 months period between 2023 and 2024. I have personally seen 4 units, 3 in Hong Kong and 1 in Malaysia, and auditioned 3 of them.
Two little questions? Plinius m14 phono?. Garrad in slate plinth?For vintage Japanese DD, the Denon DP100 would be my pick!View attachment 141668
Agree, these have very nice motor and control systems and the Tonearm is a tech marvel with coreless motors to control tracing force.for the money the best sounding direct drive turntable jvc victor ql-y77f unrestored 500-600€. recapped electronic& new plinth a phantastic machine.
and you have made two very good decisionsYes, you have good eyes![]()
I have a suggestion- many people don't realize how important the platter pad is to the sound they get. If there is resonance in the vinyl it can talk back to the stylus, coloring the sound and obscuring detail. The platter pad's job is to damp both the LP and the platter itself. One of the best ones we've heard is the Oracle platter pad (scroll down) Its meant as a permanent application (has a peel-off back). Its way better than rubber, cork or leather- all of which are a joke. Obviously your AS2000 has considerably less resonance in the platter so this could be one of the variables in the sound you are hearing.The original Denon DL103 cartridge sounds great, but I really wanted a more direct comparison to my main table, so I installed one of my spare Ortofon cartridges, matching what I have on the AS2000. Wow, this old direct drive table sounded great in my system, much better than I remember from years ago in my much more modest system. No surprise there, but I was pretty impressed. The Denon/Ortofon does nothing wrong. It is very well balanced, with great weight and body. The sound is very involving and natural. Nothing sticks out and calls attention to itself. There is good extension and what seems like very low distortion. Dynamics and presence are excellent. And the automatic buttons controlling the arm lift and movement are really cool to play with when the lid is down, and it returns the arm and shuts off when the record is finished. How cool is that?
I then listened to my American Sound AS2000. The character is very similar - well balanced, nothing sticks out, very engaging and natural sounding. The difference is in degrees of resolution. There is more nuance to strings, and piano keys hitting the strings. Low bass is more articulate, triangles and cymbals have a quicker, clearer strike and ring. And everything sounds more open. Layering and separation is better. The overall sound is cleaner and a few degrees more natural. But the interesting thing is that the character of the two tables is very similar. Nothing is harsh, hard or cold as I have heard from other turntables in my system here or elsewhere. Both are natural sounding.
I am going to keep this Denon around for a while to play for friends to see what they think. I am really quite astonished that a table that I have owned since 1980 with a nice vintage cartridge I bought on Ebay can sound this natural. I still have a few of my old records from college days. They are up next. This hobby can be a lot of fun.
I have a Brinkmann Bardo and, although it is direct drive, has that Brinkmann calmness. The Denon is more edgy sounding but the best DDs from Japan, such as my Yamaha GT-2000 and tables like the Exclusive P3/P10, don't sound edgy at all...just resolving and stable.
Do you use a particular type of thread?
Bardo sounds edgy? Not in a million years. Sp3 can easily sound edgy. These have two completely different DD implementations. One is very low torque with a coreless, brushless motor with loose control and the other uses a high torque, iron core motor with a tight PLL control system.I did hear a Bardo once and had a friend's SP10 Mk3 in my old system for a while. Of course, there are too many variables to know, but my Denon now sounds better than either of those in the other systems sounded then. They actually did sound edgy to me and not natural. There is none of that with the Denon and the Ortofon cartridge in my system.
Yes, I am sure there are better Denons and other DD tables out there. Thinking about this and the other thread about young people getting into the hobby, I think a turntable like this would be a great way to start. This was my college turntable and cost $319 from Tweeter in Boston in 1980. It is about that now on Ebay. It held its value in absolute terms. Amazing. Digital is cheap too, but it sounds very different from this.
The best modification I ever made was to remove the aluminum quick start platter on my TD 124. Then I used either Tizo Aycl Mat or Graphite Mat directly on the bright green plate. I can't describe how much better that sounds.I have a suggestion- many people don't realize how important the platter pad is to the sound they get. If there is resonance in the vinyl it can talk back to the stylus, coloring the sound and obscuring detail. The platter pad's job is to damp both the LP and the platter itself. One of the best ones we've heard is the Oracle platter pad (scroll down) Its meant as a permanent application (has a peel-off back). Its way better than rubber, cork or leather- all of which are a joke. Obviously your AS2000 has considerably less resonance in the platter so this could be one of the variables in the sound you are hearing.
Romy the Cat's take on "Natural Sound", with our own PeterA's thread as a starting point
I made it halfway trough, now i need a break !Best to close your eyes and focus on what he is saying to get through his accent.. Watching is distracting because of all the hand waving and fluttering and cigar puffing. Romy can have interesting ideas but he is a poor communicator.
I made it halfway trough, now i need a break !I prefer it to his writing, the cigar is a great comedic feature, what a character !
I have not watched Romy’s video yet, but I’ll try to get to her today.
