That was funny, sorry you didn't get it.If you are going to be snarky then at least be funny...
That is correct Stephane .. in fact if you have a narrow high backed chair you block reflections from wall behind and if upholstery is rounded you get very little reflections from chair.. your head block most of the direct sound impacting the chair back in any case ( yours is a bit too wide but you solve that to some extent with pillow)In my case, it seems to add a little focus to the sound. Waves are bouncing in the room everywhere, so there could be multiple effects, for example, blocking waves from the back. I have two chairs, a low one, and another with a high back support that extends around and above my head. This last one probably blocks some of the waves bouncing from the back and to a lesser extent the side walls. If I sit back in the chair, the sound gets muddier. With a tube-like cushion behind my neck it sounds ok.
Whatever you say Mr. Carlin…That was funny, sorry you didn't get it.
Peter,
Can you to tell us what is the measured percental variation of speed per second of you turntable when you remove the belt?
Then we can easily calculate the energy that is transferred to the platter by the motor.
Remove the belt when turning at 33.33 and record speed at each rotation. Or make a video of the tachometer for us. It would be great to have also this information with the tonearm playing.
So, three things: 1) The platter speed starts dropping significantly immediately once the power is off and 2) Stylus drag increases the rate of slow down by about 10% (3 seconds faster to 28 RPM than with the needle not engaged). 3) The string/motor also applies a lot of drag on the platter but this is likely pretty constant and once motor is active it is unlikely to be an issue.This post is from another thread, so I moved it hear. Member Microstrip asked me to make two videos showing the RoadRunner tachometer reading on my turntable when I turn off the motor. One is without the stylus in the groove and one is with the stylus in the groove. The tachometer measures the speed of the platter once per revolution and it is read at the motor controller. The third video is of the platter free spinning to a complete stop.
It is interesting to note that the tachometer display shuts off around 28 RPM. This takes about 23 seconds with the stylus in the groove, 26 seconds without the stylus in the groove, and about 5 min 30 seconds with no thread attached to the platter. When the motor is shut off, the motor and flywheel keep spinning but have more friction and slow down pretty quickly, so with the loose thread attached to the platter, they slow the platter down faster than when it is free spinning.
Changing the thread tension does affect the sound, and if it is too loose, dropping the stylus into the groove will very slightly change the tachometer reading by 0.002 RPM or so. I have the tension set so that dropping the stylus into the groove does not change the speed of the platter, but no tighter. I can also adjust the torque. I increase the torque slightly when the thread is looser. I find that the best sound is when the motor seems to influence the platter the least while still maintaining correct and consistent speed. Too loose and the sound does become slightly less focused and articulate. If the tension is too tight, the sound becomes a bit hard. Bass note decays get shortened and sound less hollow and woody. Same with drums. Overall the sound loses some richness and some weight.
Video with the arm in the armrest:
Video with the stylus in the groove:
EDIT: And here is a video that I posted before of the platter free spinning with no thread attached. You can also see the tachometer reading. Note the video is very long showing the platter rotating until it comes to a complete stop. @hb22 was asking about how long the last rotation takes as a gauge for the the quality of the bearing. He can watch the last couple minutes of this video as the platter slows to a stop.
I am surprised that the stylus has so much effect on your turntable given the mass of the platter. One would have thought that the mass inertia would find this drag insignificant but it rather suggests that the needle drag is a quite significant force. One would expect an even greater effect with a lower mass platter.
I guess for your specific design, what would be interesting would be to know how quickly or slowly the platter speed is adjusted to 33 RPM when there is a high drag situation in the music...it seems clear that a large modulation could significantly lower the speed (maybe by 0.5 to 1 RPM even) and then how quickly your platter can come back up to speed with the high mass and lowish torque (or is it rather a high torque motor?). How long does it take for your turntable to come up to speed from a stop? We could then deduce how long it takes to change speed by 0.5 or 1 RPM, as this might effect tonality of the sound coming after large groove modulations or highly dynamic material.
From what I have seen, the tacho is far to slow to show you what is happening on the musically relevant time scale. For sure your super heavy platter will be less impacted from stylus drag than a lighter platter but it will also be resistant to speeding back up for the same reason. I don't think the issue can ever be fully solved with mass based on what I am seeing. I guess I am surprised that even with the high mass of your platter that needle drag is still having a rather large effect and it suggests to me that high mass might not be the best solution to the problem and that the opposite, high torque and low mass, might be at least as valid.If all of that were true, the tachometer reading would change while I was playing music, depending on the modulations. That is not the case. The platter slows down pretty quickly because the motor stops, and so the thread is contending with the mass of the platter on one end and the rapidly slowing motor and heavy flywheel on the other end. The motor causes drag on the platter when it is shut off. This is a condition that never occurs when playing music with the motor running.
Stylus drag is very real. In my case, the platter does not change speed if I lower the stylus when the motor is on. On my old SME turntable the platter slowed down so much that I had to set the speed while playing music. That is not the case with this turntable. I can affect this by changing the tension of the thread. Too loose and the platter will slow down when I lower the stylus. I could tighten the tension, and that would change the results on the videos because then the motor slowing down is even more coupled to the platter. Now there is slippage at the motor pulley. Stylus drag is likely one of the reasons that David’s new turntable has an even more massive platter, though I have not spoken with him about this directly.
I also put up a video showing the results with the timeline strobe on the wall on the opposite side of the room while playing music. I would welcome anyone sharing videos of their turntable doing any of this stuff. But basically I made the videos because microstrip asked for them.
Thanks, Peter.
Thanks Peter. In fact I am only interested in speed measurements without the string or thread - and It seems me we miss that data on slow down with tonearm down and no string.
BTW - apologies I do not remember any more - how is the speed measured by the tachometer?
You don't think the impact would be essentially the same as tonearm up or down with the string attached?Thanks, Peter.
I know this issue with SME because a friend of mine had one and we put my Allnic Speednic on it and it was clear that it was not at the right speed when starting with the needle down; however, you could also see the speed subtly fluctuating throughout because of the needle drag. The Allnic is pretty sensitive this way, whereas my Yamaha GT-2000 was completely rock steady regardless of playing a record or not. The Yamaha is interesting because it has some mass in the platter (6KG to be exact...but with an 18KG optional platter) and has reasonable torque being a direct drive. The combination of a very smooth DD mechanism and some flywheel mass (it is also oversized with more weight at the outside) to tackle the problem multidimensionally.
Thanks - but I just need the numbers!The tachometer measures speed with a sensor on the base of the turntable and a small magnet placed on the platter, so once per revolution. It is the RoadRunner tachometer without speed correction.
I will see if I can add a video without thread of the platter slowing down.
The Sutherland Timeline is a really useful gadget. The only machines I've ever seen that were really speed stable are the Technics. You can play an LP over and over on the SL1200G or SP10 and the Timeline will have the dot in the same place all day long. Its more speed stable than my LP mastering lathe was.Stylus drag is very real. In my case, the platter does not change speed if I lower the stylus when the motor is on. On my old SME turntable the platter slowed down so much that I had to set the speed while playing music. That is not the case with this turntable. I can affect this by changing the tension of the thread. Too loose and the platter will slow down when I lower the stylus. I could tighten the tension, and that would change the results on the videos because then the motor slowing down is even more coupled to the platter. Now there is slippage at the motor pulley. Stylus drag is likely one of the reasons that David’s new turntable has an even more massive platter, though I have not spoken with him about this directly.
He immediately removed it from the spindle and told me the weight of the device affected the speed of the turntable.
