There has been a lot of mentions to the EdgeRouter X-SFP, I eventually got one and it's a great little device!
I'd just be curious to know if anyone has tried higher Ubiquity router models like EdgeRouter 12 with 2 SFP ports or have similar recommendations.
In the spirt as @nenon great post: #245
I wanted to try something along these lines, In order to isolate both home and audio networks through optical connections:
Cable Modem -> EdgeRouter 12 -> (SFP) -> EtherRegen (Audio Network)
******************************** |-> (SFP) EdgeRouter X-SFP (Home Network, WIFI)
Assuming that EdgeRouter12 could be also fed with a 12v power supply (I use Hynes SR4 for all three network components in the audio chain) and similar noise levels as the X-SFP I believe this solution should suits me well for the time being.
Another solution I had in mind would be to have the EdgeRouter X-SFP connected to the modem and have an intermediate switch (as the Buffalo BS-GS2016 mentioned above), while not excited to increase the box and LPS count by 1, I can consider it there's reasonable gains.
Let me know if you have any thoughts/suggestions
