Im NOT sure Micro would agree to
that
Big congrats, Mike!!! Huge news...absolutely huge. I am really looking forward to reading all about it. Now...are the 468s already set up to be grounded...or will you have to do something like you did with the 458s?
Got it...makes sense. I wonder if the manufacturer would be willing to do that for you? I cannot imagine any of this would negate warranty...further, presume there might be some marginal benefit if they did it for you?thanks Lloyd, i also see this as a big deal to me. there are not many other steps i can take for whole system improvements.
my 468's are pure stock, no added dedicated ground post. so yes; i will attach my Tripoint ground wires to the same spot as on the 458's; with the same screw and nut doohickey. if you look closely in the picture, those little contraptions are sitting on my baseboard shelf next to the red tower thingies.
Congrats Mike. Your decision to upgrade has not been something easy after a long road with 458's, neverthless audiophiles are restless men, we can't resist in stop mode for a long period.
I'm curious since specifications between the two models are different in terms of power vs. load; this reveals that something has been modified by Herve' Deletraz in the circuit devolved to send Watts to speaker.
Your ears will give the final answer!
Marco
"the difference in the maximum output measured power is mainly due to the fact that our main internal power supply is filtered but not regulated. A/C power mains at Michael Fremer's house presumably dropped a little during sustained power tests. Our tests are designed around an AC voltage source of 125 volts. a difference of 6-7 volts would have significant difference in output power, enough to explain the difference."
While it’s part of your system, I’d be interested in hearing what you think of 108 in comparison to the 458s. I know you had one before but now you have years of experience with the monoblocks for reference.
Totally get that. Regarding location of grounding post...that is interesting. If grounding in theory means one connection point 'touches all', then perhaps the entire construction of the 468s is not physically 100% interlinked from a grounding perspective?i originally used that screw choice in the 458's from asking Herve about it, and he pointed me to it as the likely best choice. as i recall he said with the design there would be no one ideal place for a ground post. exactly what that means i'm not sure. i much appreciated that he did help me and did not just dismiss it. (Kevin Malmgren, the Evolution Acoustics designer, gave me similar advice for the bass amp grounding).
in any case, my sense is to not push Herve to have to think about it (actually installing a ground post) too much. i imagine he might be torn between compromising his masterpiece or telling me no. did not want to do that. he knew my intentions from before and did not offer it..
agree that the listening will be the proof.
458 and 468 have similar but not the same power ratings. but any power difference is a purely academic concept in my system with 97db efficient, 7 ohm easy-peasy speakers to drive.
in Herve's manufacturer's comments to the Fremer review he makes the point that Atkinson's measurements were mostly the same he get's in his labs, and that........
The NHB468 should be a very different amplifier from the NHB458 in a subjective positive sense - its measurements are "worst" than those of the 458, looking more "tube-like"! Comparing the measurements of the amplifiers we could think that they were coming from different manufacturers - in some sense the NHB468 moves towards the old NHB 108 paradigma. Even the noise spectra show that the NHB468 has a background bottom line 15dB higher than the NHB 458, and worst signal to noise ratios.
I always felt that the NHB 458 was too analytical compared with the NHB 108 that I owned for a longtime - I should probably avoid listening to the new NHB 468, it is currrently out of my reach. I am sure that Mike will have a lot to report!
I am, as always, impressed with the knowledge and hands on experience ofThe NHB468 should be a very different amplifier from the NHB458 in a subjective positive sense - its measurements are "worst" than those of the 458, looking more "tube-like"! Comparing the measurements of the amplifiers we could think that they were coming from different manufacturers - in some sense the NHB468 moves towards the old NHB 108 paradigma. Even the noise spectra show that the NHB468 has a background bottom line 15dB higher than the NHB 458, and worst signal to noise ratios.
understand i have not yet heard the 468. if i had then i'm sure my senses would have me foaming at the mouth.
Hi MikeL,
so you decided to switch to the 468 only by the review of Michael Fremer and the confidence in the outstanding skills of Hervé?!? You did not hear them before.
What were the main areas where you expect a big step forward through your purchase of the 468?
you and Mike. You guys and your descriptions are the closest that some of
us get to hearing a lot of this gear. I just don’t trust Fremer and his agenda
as much as you
