Clamp down and suction are fundamentally different concepts.
Clamp down is to press the edge of record to the platter from the centre and tries to flatten the LP. It did very little to reduce the vibration of record surface. When a record is played, the whole vinyl surface vibrates with the music. The record is actually like the skin of a drum. It resonates and smears the sound. That’s why 180g records usually sounds better because the thicker layer of vinyl reduces resonance.
Suction presses the whole record tight onto platter, the record surface resonance is much reduced. Every record becomes 200g or 300g record. The resolution is enhanced. So it is not just flattening of record, the vibration control is also vital.
